ess:ess_mode_2_and_3
ess:ess_mode_2_and_3 [2020-07-08 15:48] – [2.1 Available control points] iburger | ess:ess_mode_2_and_3 [2020-07-09 12:51] – [2.2 Accessing the control points] iburger | ||
Line 103: | Line 103: | ||
+ | * com.victronenergy.settings / | ||
+ | * com.victronenergy.hub4 / | ||
- | Note that the paths are represented as percentage, but should be used as on/off switch (0: off, | + | Note that the MaxChargePercentage and MaxDischargePercentage |
100: on). | 100: on). | ||
