ess:ess_mode_2_and_3
ess:ess_mode_2_and_3 [2020-02-17 09:55] – [1.3 - Mode 3] iburger | ess:ess_mode_2_and_3 [2020-05-03 22:41] – [ESS mode 2 and 3] mvader | ||
Line 5: | Line 5: | ||
The here described functionality builds on top of the normal standalone operation, see [[ess: | The here described functionality builds on top of the normal standalone operation, see [[ess: | ||
+ | WARNING & DISCLAIMER: whilst publically available, Victron Energy does not offer support in professional customers or end-users that implement features using the here documented functionality, | ||
===== 1. Overview of ESS operating modes ===== | ===== 1. Overview of ESS operating modes ===== | ||
Line 33: | Line 34: | ||
=== Mode 3 with a managed battery === | === Mode 3 with a managed battery === | ||
When using Mode 3 with a managed battery, please note that the maximum discharge current sent by the battery will be ignored. The implemented control loop should take care of discharge limits communicated by the battery. | When using Mode 3 with a managed battery, please note that the maximum discharge current sent by the battery will be ignored. The implemented control loop should take care of discharge limits communicated by the battery. | ||
- | The exception to the above rule is a zero discharge limit. If a managed battery requests a zero discharge limit, the Multi will stop discharging the battery. | ||
- | * If grid power is available, the Multi will go into passthru. | ||
- | * If grid power is not available, the Multi will switch off. | ||
The maximum charge current sent by a managed battery is however always heeded and cannot be overruled by the setpoint. | The maximum charge current sent by a managed battery is however always heeded and cannot be overruled by the setpoint. |
