ess:ess_mode_2_and_3
ess:ess_mode_2_and_3 [2019-01-22 10:16] – external edit 127.0.0.1 | ess:ess_mode_2_and_3 [2019-08-15 12:39] – replace venus-device with GX device guy_stewart | ||
Line 26: | Line 26: | ||
Necessary Victron equipment: | Necessary Victron equipment: | ||
* Multi or Quattro inverter/ | * Multi or Quattro inverter/ | ||
* Note that there is no AC sensor necessary, since the inverter/ | * Note that there is no AC sensor necessary, since the inverter/ | ||
Line 64: | Line 64: | ||
- | MQTT is available both on the local broker on the [[venus-os: | + | MQTT is available both on the local broker on the [[venus-os: |
=== C) Running your own scripts on the CCGX === | === C) Running your own scripts on the CCGX === |
