ess:ess_mode_2_and_3
ess:ess_mode_2_and_3 [2018-10-26 23:29] – [3.6 Using the MK3 directly instead of CCGX] guy_stewart | ess:ess_mode_2_and_3 [2019-08-15 12:39] – replace venus-device with GX device guy_stewart | ||
Line 26: | Line 26: | ||
Necessary Victron equipment: | Necessary Victron equipment: | ||
* Multi or Quattro inverter/ | * Multi or Quattro inverter/ | ||
- | * Venus-device | + | * [[venus-os: |
* Note that there is no AC sensor necessary, since the inverter/ | * Note that there is no AC sensor necessary, since the inverter/ | ||
Line 64: | Line 64: | ||
- | MQTT is available both on the local broker on the Venus-device, as well as remotely through the secure could connection. | + | MQTT is available both on the local broker on the [[venus-os: |
=== C) Running your own scripts on the CCGX === | === C) Running your own scripts on the CCGX === | ||
Line 322: | Line 322: | ||
* Set register 39 to 0 | * Set register 39 to 0 | ||
* Set register 37 to -1000 | * Set register 37 to -1000 | ||
