ess:design-installation-manual [2019-04-03 13:27] – guy_stewart | ess:design-installation-manual [2021-01-14 08:35] (current) – marmour | ||
- | * [[https:// | + | |
- | * Marine systems. | + | |
- | See [[ess: | + | |
- | === Inverter/ | + | |
- | === Venus-device === | + | |
- | === Battery === | + | |
- | * https:// | + | |
- | https:// | + | |
- | A grid meter is only // | + | |
- | ==== 2.1 PV ==== | + | |
- | __Feed-in__ | + | |
- | __No feed-in__ | + | |
- | * on the AC out. | + | |
- | See [[: | + | |
- | ==== 4.2 Multi/ | + | |
- | General notes: | + | |
- | ==== 4.3 Venus-device - ESS Settings ==== | + | |
- | ** BatteryLife ** | + | |
- | * OPzV, OPzS | + | |
- | * GEL / AGM | + | |
- | Setting this to ' | + | |
- | Set to ' | + | |
- | Notes: | + | |
- | * In Settings-> | + | |
- | ==== 4.4 Venus-device - Scheduled Charging ==== | + | |
- | ==== 4.5 Venus-device - Other settings ==== | + | |
- | The blue ' | + | |
- | __Mains present__ | + | |
- | __Mains outage__ | + | |
- | * Dynamic cut-off | + | |
- | The // | + | |
- | === Details === | + | |
- | The dynamic // | + | |
- | Notes: | + | |
- | ==== 6.5 ESS Battery Status Code Numbers ==== | + | |
- | In addition to the charger states (Bulk/ | + | |
- | The key for these codes is: | + | |
- | * #1: SOC is low | + | |
- | ^ ^ L1^ | + | |
- | ^ Load | + | |
- | * The Multi' | + | |
- | === Policies === | + | |
- | For example // | + | |
- | === Make use of ' | + | |
- | The ESS // | + | |
- | * In __Optimize mode__ whether the load is great or small power will be supplied by the batteries. The Grid meter will be kept at 0W until either the battery is drained or the load exceeds the inverter' | + | |
- | * In __Keep Batteries charged mode__ no power comes from the batteries to power loads unless the grid fails. PV power, when available, will be used to power the loads. There is a known issue when using “Keep batteries charged” mode that can result in less production from the MPPT solar charger when batteries are full. This only occurs when [[https:// | + | |
- | The current options to work around this "Keep Batteries charged" | + | |
- | * Enable [[https:// | + | |
- | * Set the mode to Optimize, and set the minimum SOC to 100%. Note that with this workaround there is still a difference with the “Keep batteries charged” mode: the system will not recharge the battery from the grid after a power outage | + | |
- | * When discharge is not allowed (BMS max discharge current = 0A, or low SOC, etc...) and loads on AC-Out force the Multi/ | + | |
- | * The MPPTs are always in the `ESS` state. This indicates that the MPPT is being controlled by the Multi or Quattro via the Venus-device. To view the system state, look at the VE.Bus State. | + | |
- | * Others: | + | |
- | === Q9: Why does my MultiGrid refuse to feed-in? === | + | |
- | A MultiGrid system can enter a state where feed-in (more precisely: converting DC to AC while connected to the grid) is disabled.\\ This happens when, at the moment of connection to the grid, there is not enough DC power to perform the required relay test. (N.B. this relay test is part of the grid code specification - and is mandatory). In order to perform this test the Multigrid must be able to run from battery during a period of time (depending on the selected grid code but usually about 1 minute).\\ If this is not possible, the system enters a // | + | |
- | Therefore there is no need to worry - the system will resume feed-in automatically once the battery has been charged. | + | |
- | === Q11: My Battery is not discharging === | + | |
- | A similar wording for the same question is: my loads are being powered from the mains, rather than the battery. | + | |
- | See the [[# | + | |
- | === Q12: What is auto-recharge? | + | |
- | === Q13: Can I use ESS in a vehicle or a boat? === | + | |
- | The same applies to other solutions where the wiring is not protected against accidental removing, for example a simple cable with end-user removable plug, such as a portable power supply. | + | |
ess/design-installation-manual.1554290856.txt.gz · Last modified: 2019-04-03 13:27 by guy_stewart
