energy-meters:start
energy-meters:start [2019-09-08 17:47] – [3. FAQ] mvader | energy-meters:start [2020-08-13 02:56] – guy_stewart | ||
Line 6: | Line 6: | ||
===== 1. Selection guide ===== | ===== 1. Selection guide ===== | ||
+ | ^ __Energy Meter__ | ||
+ | | Appearance | ||
+ | | Display | ||
+ | | Manual and Wiring Diagrams* | [[et112|ET112 Manual]] | ||
+ | | Part Number | REL300100000 | ||
+ | | Supported Phases | 1 phase | 3 phase | 3 phase | | ||
+ | | Maximum Current Rating | 100A | 65A per phase | 65A per phase | | ||
+ | | Measurement Type | Shunt | Shunt | Shunt | | ||
+ | * Including RS485 to GX device instructions. | ||
=== First decide if you need single- or three phase meters === | === First decide if you need single- or three phase meters === | ||
Line 12: | Line 23: | ||
=== Now, based on current, select the model === | === Now, based on current, select the model === | ||
- | ^ Requirement | + | ^ Requirement |
- | ^ ::: ^ ::: ^ Part number | + | | Single phase up to 100A | Shunt | ET112 | |
- | | Single phase up to 100A | Shunt | REL300100000 | + | | Three phase up to 65A/ |
- | | Three phase up to 65A/ | + | | Single phase more than 100A/phase | CT | Not available, use the three phase CT solution |
- | | Single phase more than 100A/phase | CT | Not available, use the three phase CT solution | + | | Three phase more than 65A/ |
- | Besides above meters, we also stock the ET340 meter; REL300300000. It counts energy in a different way than the EM24. For Germany and most other countries; the EM24 is the advised model. See FAQ Q5 and Q9 for details. | + | The EM24 meter counts energy in a different way than the ET340. For Germany and most other countries; the EM24 is the advised model. See FAQ Q5 and Q9 for further |
=== 1.1 Support for other Carlo Gavazzi meters === | === 1.1 Support for other Carlo Gavazzi meters === | ||
Line 35: | Line 45: | ||
^ EM271 | Not supported | does not report exported energy, | ^ EM271 | Not supported | does not report exported energy, | ||
^ ::: | ::: | com protocol not compatible with supported grid meters | ^ ::: | ::: | com protocol not compatible with supported grid meters | ||
- | ===== 2. Manuals ===== | ||
- | * [[et112|REL300100000 - ET112 - 1 phase - max 100A]] | ||
- | * [[et340|REL300300000 - ET340 - 3 phase max 65A/phase]] | ||
- | * [[em24|REL200100000 - EM24 - 3 phase max 65A/phase]] | ||
