energy-meters:start
energy-meters:start [2019-08-15 12:49] – replace venus-device with GX device guy_stewart | energy-meters:start [2020-09-07 11:59] – [1. Selection guide] mvader | ||
Line 6: | Line 6: | ||
===== 1. Selection guide ===== | ===== 1. Selection guide ===== | ||
+ | ^ __Energy Meter__ | ||
+ | | Appearance | ||
+ | | Display | ||
+ | | Manual and Wiring Diagrams | [[et112|ET112 Manual]] | ||
+ | | Part Number | REL300100000 | ||
+ | | Supported Phases | 1 phase | 3 phase ||| | ||
+ | | Maximum Current Rating | 100A | 65A per phase ||| | ||
+ | | Measurement Type | Shunt |||| | ||
+ | | Data connection | RS485 ||| Ethernet | ||
=== First decide if you need single- or three phase meters === | === First decide if you need single- or three phase meters === | ||
- | For a three phase utility connection, use a three phase meter. For a three phase PV Inverter, use a three phase meter as well. For a single phase utility connection, use a single phase meter. And in an installation with a single phase utility connection, that also has a PV Inverter that needs measuring with a Victron meter, then you can use Rutger | + | For a three phase utility connection, use a three phase meter. For a three phase PV Inverter, use a three phase meter as well. For a single phase utility connection, use a single phase meter. And in an installation with a single phase utility connection, that also has a PV Inverter that needs measuring with a Victron meter, then you can use 2 pieces of ET112; or use the ET340. |
- | === Now, based on current, select the model === | + | === Now, based on current, select the model: === |
- | ^ Requirement | + | ^ Requirement |
- | ^ ::: ^ ::: ^ Part number | + | | Single phase up to 100A | Shunt | ET112 | |
- | | Single phase up to 100A | Shunt | REL300100000 | + | | Three phase up to 65A/ |
- | | Three phase up to 65A/ | + | | Single phase more than 100A/phase | CT | Not available, use the three phase CT solution |
- | | Single phase more than 100A/phase | CT | Not available, use the three phase CT solution | + | | Three phase more than 65A/ |
- | Besides above meters, we also stock the ET340 meter; REL300300000. It counts energy in a different way than the EM24. For Germany and most other countries; the EM24 is the advised model. See FAQ Q5 and Q9 for details. | + | The EM24 meter counts energy in a different way than the ET340. For Germany and most other countries; the EM24 is the advised model. See FAQ Q5 and Q9 for further |
- | === 1.1 Support for other Carlo Gavazzi meters === | + | === In case of EM24, select between RS485 and Ethernet connection: === |
+ | The Ethernet model will have an advantage in installations where an Ethernet network is available. Rather than having to pull an RS485 wire between the main AC distribution board and the storage system, the existing Ethernet can be used. | ||
+ | The disadvantage is that this relies on that network functioning properly - in case of issues the Storage system will switch to idle mode: passthrough. | ||
+ | ===== 2. Support for other Carlo Gavazzi meters | ||
Besides above listed meters, there are many more meters available from Carlo Gavazzi. Use this list to see which ones are compatible. | Besides above listed meters, there are many more meters available from Carlo Gavazzi. Use this list to see which ones are compatible. | ||
Line 35: | Line 51: | ||
^ EM271 | Not supported | does not report exported energy, | ^ EM271 | Not supported | does not report exported energy, | ||
^ ::: | ::: | com protocol not compatible with supported grid meters | ^ ::: | ::: | com protocol not compatible with supported grid meters | ||
- | ===== 2. Manuals ===== | ||
- | * [[et112|REL300100000 - ET112 - 1 phase - max 100A]] | ||
- | * [[et340|REL300300000 - ET340 - 3 phase max 65A/phase]] | ||
- | * [[em24|REL200100000 - EM24 - 3 phase max 65A/phase]] | ||
Line 68: | Line 78: | ||
Three-phase new meter only (ET340): | Three-phase new meter only (ET340): | ||
- | * Measuring Energy from single phase PV Inverter on the second phase of the new meter, ET340, actually works. Where-as with the old meter, the EM24, only the Power Metering (Watts) works. The Energy Metering (kWh) for a single phase PV Inverter on the second phase of the EM24 does not work. | + | * Measuring Energy from single phase PV Inverter on the second phase of the new meter, ET340, actually works. Where-as with the old meter, the EM24, only the Power Metering (Watts) works. The Energy Metering (kWh) for a single phase PV Inverter on the second phase of the EM24 does not work. See Q9 for the details. |
=== Q6: Will you keep shipping both 3 phase meters? (ET340 & EM24) === | === Q6: Will you keep shipping both 3 phase meters? (ET340 & EM24) === |
