energy-meters:start
energy-meters:start [2019-01-22 10:16] – external edit 127.0.0.1 | energy-meters:start [2019-09-08 17:47] – [3. FAQ] mvader | ||
At Victron Energy, we stock several types of Energy Meters. | At Victron Energy, we stock several types of Energy Meters. | ||
- | The Energy Meters are used in systems with a Venus-device. To measure the output of a PV inverter (more info in the Venus-OS manual [[https:// | + | The Energy Meters are used in systems with a [[venus-os: |
===== 1. Selection guide ===== | ===== 1. Selection guide ===== | ||
Line 68: | Line 68: | ||
Three-phase new meter only (ET340): | Three-phase new meter only (ET340): | ||
- | * Measuring Energy from single phase PV Inverter on the second phase of the new meter, ET340, actually works. Where-as with the old meter, the EM24, only the Power Metering (Watts) works. The Energy Metering (kWh) for a single phase PV Inverter on the second phase of the EM24 does not work. | + | * Measuring Energy from single phase PV Inverter on the second phase of the new meter, ET340, actually works. Where-as with the old meter, the EM24, only the Power Metering (Watts) works. The Energy Metering (kWh) for a single phase PV Inverter on the second phase of the EM24 does not work. See Q9 for the details. |
=== Q6: Will you keep shipping both 3 phase meters? (ET340 & EM24) === | === Q6: Will you keep shipping both 3 phase meters? (ET340 & EM24) === | ||
Line 110: | Line 110: | ||
