energy-meters:start
energy-meters:start [2018-12-04 08:22] – [1. Selection guide] mvader | energy-meters:start [2022-09-13 14:42] (current) – stefanie | ||
- | ====== Energy Meters start page ===== | + | The old Energy Meter datasheet and selection |
- | At Victron Energy, we stock several types of Energy Meters. | + | |
- | The Energy | + | |
- | ===== 1. Selection | + | |
- | === First decide if you need single- or three phase meters === | + | |
- | For a three phase utility connection, use a three phase meter. For a three phase PV Inverter, use a three phase meter as well. For a single phase utility connection, use a single phase meter. And in an installation with a single phase utility connection, that also has a PV Inverter that needs measuring with a Victron meter, then you can use Rutger 2 pieces of ET112; or use the ET340. | + | |
- | === Now, based on current, select the model === | + | |
- | ^ Requirement | + | |
- | ^ ::: ^ ::: ^ Part number | + | |
- | | Single phase up to 100A | Shunt | REL300100000 | ET112 | 1 phase - max 100A | | + | |
- | | Three phase up to 65A/ | + | |
- | | Single phase more than 100A/phase | CT | Not available, use the three phase CT solution | + | |
- | Besides above meters, we also stock the ET340 meter; REL300300000. It counts energy in a different way than the EM24. For Germany and most other countries; the EM24 is the advised model. See FAQ Q5 and Q9 for details. | + | |
- | === 1.1 Support for other Carlo Gavazzi meters === | + | |
- | Besides above listed meters, there are many more meters available from Carlo Gavazzi. Use this list to see which ones are compatible. | + | |
- | ^ Type ^ Support | + | |
- | ^ EM111 | Supported | + | |
- | ^ ET111 | Supported | + | |
- | ^ EM112 | Supported | + | |
- | ^ ET340 | Supported | + | |
- | ^ EM340 | Not supported | does not report exported energy per phase (unlike the ET340) | | + | |
- | ^ EM21 72D | Not supported | does not report exported energy, | + | |
- | ^ ::: | ::: | com protocol not compatible with supported grid meters | + | |
- | ^ EM271 | Not supported | does not report exported energy, | + | |
- | ===== 2. Manuals ===== | + | |
- | * [[et112|REL300100000 - ET112 - 1 phase - max 100A]] | + | |
- | * [[et340|REL300300000 - ET340 - 3 phase max 65A/ | + | |
- | * [[em24|REL200100000 - EM24 - 3 phase max 65A/ | + | |
- | No. | + | |
- | No. | + | |
- | No. | + | |
- | === Q5: What are the differences between the various three phase meters? === | + | |
- | * EM24 - REL200100000 - Carlo Gavazzi EM24DINAV93XISX | + | |
- | * ET112 - REL300100000 - Carlo Gavazzi ET112-DIN.AV01.X.S1.X | + | |
- | * ET340 - REL300300000 - Carlo Gavazzi ET340-DIN.AV23.X.S1.X | + | |
- | Differences: | + | |
- | * The ET meters don't have a front selector that the installer needs to put in a different setting than it comes out of the box: easier, less mistakes to be made. | + | |
- | * The ET meters have no display. The only thing they have is an LED, which blinks in case of active communication. | + | |
- | * The new meters have 2 RJ45 sockets for the Modbus RS485 connection. But they are not used. Note the possible confusion because of yet another RJ-45 socket in the Victron world though. Don't mix that with VE.Bus, VE.Can or VE.net. Besides the RJ-45 sockets, the meters still also have screw terminals access below the sockets for the RS485 wiring, which is how we advise to connect a meter to the [[https:// | + | |
- | * Since there is no display, the Modbus address can no longer be changed on the meter. Combining multiple of those meters on one RS485 network is therefore not supported by Victron. You are advised to use multiple RS485 to USB interfaces. | + | |
- | * Measuring | + | |
- | === Q6: Will you keep shipping both 3 phase meters? (ET340 & EM24) === | + | |
- | Yes. There are still situations suitable for each. See Q9. | + | |
- | === Q9: What’s the difference between ET340 and EM24 in 3 phase systems? === | + | |
- | These meters have a different way of calculating the total of energy imported and exported. | + | |
- | In the ET340 - the energy imported and exported is counted at each individual phase and then the Total is provided from the sum of those values. | + | |
- | In the EM24 - the energy imported and exported is counted as a total power, with net differential readings from each phase cancelling each other out. | + | |
- | Which meter is best to use with depend on your countries own metering configuration. | + | |
- | It is most common in Australia and Germany for example to only be billed for the total in a 3 phase system. So it is more accurate to use an EM24 to match the billing. | + | |
- | So if you are exporting from one phase, and importing from another phase after the energy meter, but before the billing meter then you will not be charged for this, and the meter should not count it as an import and an export. | + | |
- | This is also how Victron’s phase compensation feature works, to make the most of the cost savings for an ESS system when there is a differential in generation and load across different phases. | + | |
