energy-meters:start
energy-meters:start [2018-12-04 08:22] – [1. Selection guide] mvader | energy-meters:start [2019-01-22 10:16] – external edit 127.0.0.1 | ||
Line 46: | Line 46: | ||
=== Q1: Can I combine three ET112s for a three phase system? === | === Q1: Can I combine three ET112s for a three phase system? === | ||
- | No. | + | No. Use a real three-phase meter. |
=== Q2: Can I use other meters, for example from other brands? === | === Q2: Can I use other meters, for example from other brands? === | ||
Line 100: | Line 100: | ||
This is also how Victron’s phase compensation feature works, to make the most of the cost savings for an ESS system when there is a differential in generation and load across different phases. | This is also how Victron’s phase compensation feature works, to make the most of the cost savings for an ESS system when there is a differential in generation and load across different phases. | ||
- | ===== DISQUS ===== | + | === Q10: Can I use an isolated USB-RS485 interface? |
+ | Yes. The interfaces we sell are non isolated; suitable for most use cases. | ||
+ | In case an isolated one is needed; purchase it dirsctly from [[https:// | ||
+ | * USB485-STIXL : Isolated USB to RS485 converter | ||
