energy-meters:start
energy-meters:start [2018-11-30 22:59] – mvader | energy-meters:start [2022-06-23 13:22] – [1. Selection guide] update links to new HTML5 manuals stefanie | ||
====== Energy Meters start page ===== | ====== Energy Meters start page ===== | ||
- | At Victron Energy, we stock several types of Energy Meters | + | At Victron Energy, we stock several types of Energy Meters. |
- | * ET112 for single phase monitoring (including a single phase inverter in a 3 phase system) | + | |
- | * ET340 for multi-phase installations | + | |
- | * EM24 for 3 phase monitoring only. | + | |
- | The Energy Meters are used in systems with a Venus-device. To measure the output of a grid inverter (more info in the Venus-OS manual [[https:// | + | The Energy Meters are used in systems with a [[venus-os: |
===== 1. Selection guide ===== | ===== 1. Selection guide ===== | ||
- | ^ Requirement | ||
- | ^ ::: ^ ::: ^ Part number | ||
- | | Single phase up to 100A | Shunt | REL300100000 | ET112 | 1 phase - max 100A | | ||
- | | Three phase up to 65A/ | ||
- | | Single phase more than 100A/phase | CT | See three phase CT solution | ||
- | | Three phase more than 65A/ | ||
- | Besides above meters, we also stock the ET340 meter; REL300300000. It counts | + | ^ __Energy Meter__ |
+ | | Appearance | ||
+ | | Display | ||
+ | | Manual | ||
+ | | Part Number | REL300100000 | ||
+ | | Supported Phases | 1 phase | 3 phase ||| | ||
+ | | Maximum Current Rating | 100A | 65A per phase ||| | ||
+ | | Measurement Type | Shunt |||| | ||
+ | | Data connection | RS485 ||| Ethernet | ||
- | === 1.1 Support for other Carlo Gavazzi meters === | + | |
+ | === First decide if you need single- or three phase meters === | ||
+ | For a three phase utility connection, use a three phase meter. For a three phase PV Inverter, use a three phase meter as well. For a single phase utility connection, use a single phase meter. And in an installation with a single phase utility connection, that also has a PV Inverter that needs measuring with a Victron meter, then you can use 2 pieces of ET112; or use the ET340. | ||
+ | === Now, based on current, select the model: === | ||
+ | ^ Requirement | ||
+ | | Single phase up to 100A | Shunt | ET112 | | ||
+ | | Three phase up to 65A/ | ||
+ | | Single phase more than 100A/phase | CT | Not available, use the three phase CT solution | ||
+ | | Three phase more than 65A/ | ||
+ | The EM24 meter counts energy in a different way than the ET340. For Germany and most other countries; the EM24 is the advised model. See FAQ Q5 and Q9 for further details regarding energy counting differences. | ||
+ | === In case of EM24, select between RS485 and Ethernet connection: === | ||
+ | The Ethernet model will have an advantage in installations where an Ethernet network is available. Rather than having to pull an RS485 wire between the main AC distribution board and the storage system, the existing Ethernet can be used. | ||
+ | The disadvantage is that this relies on that network functioning properly - in case of issues the Storage system will switch to idle mode: passthrough. | ||
+ | ===== 2. Support for other Carlo Gavazzi meters | ||
Besides above listed meters, there are many more meters available from Carlo Gavazzi. Use this list to see which ones are compatible. | Besides above listed meters, there are many more meters available from Carlo Gavazzi. Use this list to see which ones are compatible. | ||
Line 32: | Line 51: | ||
^ EM271 | Not supported | does not report exported energy, | ^ EM271 | Not supported | does not report exported energy, | ||
^ ::: | ::: | com protocol not compatible with supported grid meters | ^ ::: | ::: | com protocol not compatible with supported grid meters | ||
- | ===== 2. Manuals ===== | ||
- | * [[et112|REL300100000 - ET112 - 1 phase - max 100A]] | ||
- | * [[et340|REL300300000 - ET340 - 3 phase max 65A/phase]] | ||
- | No longer used: | ||
- | * [[em24|REL200100000 - EM24 - 3 phase max 65A/phase]] | ||
Line 45: | Line 56: | ||
=== Q1: Can I combine three ET112s for a three phase system? === | === Q1: Can I combine three ET112s for a three phase system? === | ||
- | No. | + | No. Use a real three-phase meter. |
=== Q2: Can I use other meters, for example from other brands? === | === Q2: Can I use other meters, for example from other brands? === | ||
Line 67: | Line 78: | ||
Three-phase new meter only (ET340): | Three-phase new meter only (ET340): | ||
- | * Measuring Energy from single phase PV Inverter on the second phase of the new meter, ET340, actually works. Where-as with the old meter, the EM24, only the Power Metering (Watts) works. The Energy Metering (kWh) for a single phase PV Inverter on the second phase of the EM24 does not work. | + | * Measuring Energy from single phase PV Inverter on the second phase of the new meter, ET340, actually works. Where-as with the old meter, the EM24, only the Power Metering (Watts) works. The Energy Metering (kWh) for a single phase PV Inverter on the second phase of the EM24 does not work. See Q9 for the details. |
=== Q6: Will you keep shipping both 3 phase meters? (ET340 & EM24) === | === Q6: Will you keep shipping both 3 phase meters? (ET340 & EM24) === | ||
Line 99: | Line 110: | ||
This is also how Victron’s phase compensation feature works, to make the most of the cost savings for an ESS system when there is a differential in generation and load across different phases. | This is also how Victron’s phase compensation feature works, to make the most of the cost savings for an ESS system when there is a differential in generation and load across different phases. | ||
- | ===== DISQUS ===== | + | === Q10: Can I use an isolated USB-RS485 interface? |
+ | Yes. The interfaces we sell are non isolated; suitable for most use cases. | ||
+ | In case an isolated one is needed; purchase it directly from [[https:// | ||
+ | * USB485-STIXL : Isolated USB to RS485 converter | ||
+ | === Q11: Can I use Victron energy meters instead of a Victron Inverter/ | ||
+ | Energy meters are intended only to supplement a Victron inverter charger in the system. | ||
+ | Energy Meters are currently limited in their potential applications. Each energy meter is only intended to provide a specific piece of additional information - total loads on AC input and grid import/ | ||
+ | In GX device firmware version 2.80 and later - They can also be used for other purposes e.g. to measure specific, arbitrary AC loads or circuits for example. | ||
+ | However it should not be considered a replacement to having a Victron inverter / charger. Attempting to use other brand battery inverters and trying to substitute their lack of data connectivity to the GX device by using energy meters will not work as expected. | ||
~~DISQUS~~ | ~~DISQUS~~ |
