energy-meters:start
energy-meters:start [2018-11-30 22:59] – mvader | energy-meters:start [2019-01-22 10:16] – external edit 127.0.0.1 | ||
====== Energy Meters start page ===== | ====== Energy Meters start page ===== | ||
- | At Victron Energy, we stock several types of Energy Meters | + | At Victron Energy, we stock several types of Energy Meters. |
- | * ET112 for single phase monitoring (including a single phase inverter in a 3 phase system) | + | |
- | * ET340 for multi-phase installations | + | |
- | * EM24 for 3 phase monitoring only. | + | |
- | The Energy Meters are used in systems with a Venus-device. To measure the output of a grid inverter (more info in the Venus-OS manual [[https:// | + | The Energy Meters are used in systems with a Venus-device. To measure the output of a PV inverter (more info in the Venus-OS manual [[https:// |
===== 1. Selection guide ===== | ===== 1. Selection guide ===== | ||
+ | === First decide if you need single- or three phase meters === | ||
+ | For a three phase utility connection, use a three phase meter. For a three phase PV Inverter, use a three phase meter as well. For a single phase utility connection, use a single phase meter. And in an installation with a single phase utility connection, that also has a PV Inverter that needs measuring with a Victron meter, then you can use Rutger 2 pieces of ET112; or use the ET340. | ||
+ | === Now, based on current, select the model === | ||
^ Requirement | ^ Requirement | ||
^ ::: ^ ::: ^ Part number | ^ ::: ^ ::: ^ Part number | ||
| Single phase up to 100A | Shunt | REL300100000 | ET112 | 1 phase - max 100A | | | Single phase up to 100A | Shunt | REL300100000 | ET112 | 1 phase - max 100A | | ||
| Three phase up to 65A/ | | Three phase up to 65A/ | ||
- | | Single phase more than 100A/phase | CT | See three phase CT solution | + | | Single phase more than 100A/phase | CT | Not available, use the three phase CT solution |
| Three phase more than 65A/ | | Three phase more than 65A/ | ||
Line 37: | Line 40: | ||
* [[et112|REL300100000 - ET112 - 1 phase - max 100A]] | * [[et112|REL300100000 - ET112 - 1 phase - max 100A]] | ||
* [[et340|REL300300000 - ET340 - 3 phase max 65A/phase]] | * [[et340|REL300300000 - ET340 - 3 phase max 65A/phase]] | ||
- | No longer used: | ||
* [[em24|REL200100000 - EM24 - 3 phase max 65A/phase]] | * [[em24|REL200100000 - EM24 - 3 phase max 65A/phase]] | ||
Line 45: | Line 46: | ||
=== Q1: Can I combine three ET112s for a three phase system? === | === Q1: Can I combine three ET112s for a three phase system? === | ||
- | No. | + | No. Use a real three-phase meter. |
=== Q2: Can I use other meters, for example from other brands? === | === Q2: Can I use other meters, for example from other brands? === | ||
Line 99: | Line 100: | ||
This is also how Victron’s phase compensation feature works, to make the most of the cost savings for an ESS system when there is a differential in generation and load across different phases. | This is also how Victron’s phase compensation feature works, to make the most of the cost savings for an ESS system when there is a differential in generation and load across different phases. | ||
- | ===== DISQUS ===== | + | === Q10: Can I use an isolated USB-RS485 interface? |
+ | Yes. The interfaces we sell are non isolated; suitable for most use cases. | ||
+ | In case an isolated one is needed; purchase it dirsctly from [[https:// | ||
+ | * USB485-STIXL : Isolated USB to RS485 converter | ||
