energy-meters:start
energy-meters:start [2017-04-04 13:16] – [1. Selection guide] mvader | energy-meters:start [2022-09-13 10:41] – [Energy Meters start page] removed and linked to the product page datasheet stefanie | ||
- | ====== | + | The old Energy |
- | At Victron Energy, we stock two types of Energy Meters: the ET112 for single phase installations, | + | |
- | ===== 1. Selection guide ===== | + | |
- | ^ Requirement | + | |
- | ^ ::: ^ ::: ^ Part number | + | |
- | | Single phase up to 100A | Shunt | REL300100000 | ET112 | 1 phase - max 100A | | + | |
- | | Three phase up to 65A/phase | Shunt | REL200100000 | EM24 | 3 phase - max 65A/phase | | + | |
- | | Single phase more than 100A/phase | CT | See three phase CT solution | + | |
- | === 1.1 Support for other Carlo Gavazzi meters === | + | |
- | Besides above listed meters, there are many more meters available from Carlo Gavazzi. Use this list to see which ones are compatible. | + | |
- | ^ Type ^ Support | + | |
- | ^ EM112 | Supported | + | |
- | ^ ET340 | Supported | + | |
- | ^ EM340 | Not supported | does not report exported energy per phase (unlike the ET340) | | + | |
- | ^ EM21 72D | Not supported | does not report exported energy, | + | |
- | ^ EM271 | Not supported | does not report exported energy, | + | |
- | ^ ::: | ::: | com protocol not compatible with supported grid meters | + | |
- | ===== 2. Manuals ===== | + | |
- | * [[et112|REL300100000 - ET112 - 1 phase - max 100A]] | + | |
- | * [[em24|REL200100000 - EM24 - 3 phase max 65A/phase]] | + | |
- | * [[et340|REL300300000 - ET340 - 3 phase max 65A/phase]] | + | |
- | No. | + | |
- | No. | + | |
- | No. | + | |
- | === Q4: When do you start shipping the ET340? === | + | |
- | We start shipping the REL300300000, | + | |
- | Its predecessor is the REL200100000 | + | |
- | === Q5: What are the differences between the old and new three meters? === | + | |
- | Old meter: REL200100000 | + | |
- | New meters: | + | |
- | * REL300100000 | + | |
- | * REL300300000 - Carlo Gavazzi ET340-DIN.AV23.X.S1.X | + | |
- | Differences: | + | |
- | * The new meters don't have a front selector that the installer needs to put in a different setting than it comes out of the box: easier, less mistakes to be made. | + | |
- | * The new meters have no display. The only thing they have is an LED, which blinks in case of active communication. | + | |
- | * The new meters have 2 RJ45 sockets for the Modbus RS485 connection. But they are not used. Note the possible confusion because of yet another RJ-45 socket in the Victron world though. Don't mix that with VE.Bus, VE.Can or VE.net. Besides the RJ-45 sockets, the meters still also have terminals for the RS485 wiring, which is how we advise to connect a meter to the CCGX. | + | |
- | * Since there is no display, the Modbus address can no longer be changed on the meter. Combining multiple of those meters on one RS485 network is therefore not possible. | + | |
- | * Measuring a single phase PV Inverter on the second phase of the meter actually works. Where-as with the old meter only the Power Metering (Watts) worked, and the Energy Metering (kWh) did not. | + | |
- | === Q6: Will you keep shipping the old meter? (EM24) === | + | |
- | No. | + | |
- | Why not? Because it is more expensive than the new one. | + | |
- | And also because measuring a single phase inverter on the second phase does not work 100%. | + | |
- | In case you still prefer to use the EM24, you can always buy that from Carlo Gavazzi directly, or through one of their distributors. | + | |
~~DISQUS~~ | ~~DISQUS~~ |
