energy-meters:et340
energy-meters:et340 [2020-06-29 22:45] – [Option A: wireless Zigbee connection] added min. Venus version boekel | energy-meters:et340 [2022-07-15 10:58] (current) – Removed and linked to new manuals stefanie | ||
- | ====== | + | The old Energy Meter manuals have been removed. You can find the new manuals here: [[https://www.victronenergy.com/accessories/ |
- | This document is the manual for the 3 phase max 65A per phase Energy Meter. | + | |
- | The Energy Meter can be used to: | + | |
- | - Grid meter, and used as control input for an [[assistants:ess-assistant|ESS System]] (1). | + | |
- | ===== 2. AC Wiring ===== | + | |
- | === 3-phase diagram: === | + | |
- | When used to measure a PV Inverter, terminals 1, 2 and 3 should face the PV inverter to ensure correct direction of current and power. | + | |
- | === Single phase dual function diagram: === | + | |
- | In this diagram, a single meter is used to both measure the grid and a single phase PV Inverter. | + | |
- | On the CCGX go to the grid meter in the Wired AC sensor settings. Make sure 'Phase type' is set to ' | + | |
- | === Step 1. === | + | |
- | === Step 2. === | + | |
- | Connect the Zigbee to RS485 converter to the ET340 energy meter: | + | |
- | | GND | Terminal 10 | | + | |
- | | A | Terminal | + | |
- | | B | Terminal | + | |
- | === Step 3. === | + | |
- | === Step 4. === | + | |
- | === note on old and new zigbee converters === | + | |
- | Please note that there is a new zigbee converter available now, that is -not- backwards compatible with the old converters. If you have a non compatible set, please ask your supplier for a correct version. | + | |
- | ASS300400100 - Zigbee to RS485 converter partnumber: DRF2619C | + | |
- | ASS300400100 - Zigbee to USB converter | + | |
- | ASS300420100 - Zigbee to RS485 converter partnumber: DRF2659C | + | |
- | ASS300420200 - Zigbee to USB converter | + | |
- | == note on GX firmware versions: == | + | |
- | for the new type Zigbee converters, Venus OS v2.54 is the minimum required software version | + | |
- | Connect the Energy Meter to the CCGX using the USB to RS485 cable. The RS485 to USB interface cable between the CCGX and the Energy Meter can be extended up to 100 meters; make sure that the extensions of the Data+ (orange) and Data- (yellow) wires form a twisted pair. | + | |
- | | Yellow (Data-) | + | |
- | | Orange (Data+) | + | |
- | | Black (GND) | Terminal 10 | | + | |
- | The red, green and brown wire coming out of the USB to RS485 cable are not used. | + | |
- | {{ :energy-meters: | + | |
- | ===== 4. Multiple Energy Meters in one system ===== | + | |
- | To connect multiple Energy Meters, wire each meter to a separate RS485-USB converter. Which are then each plugged into a separate USB socket on the CCGX. | + | |
- | Connecting multiple ET340 meters to the same RS485-USB cable is not possible: the ET340 meter has no display and its Modbus address can therefor not be changed. | + | |
