energy-meters:et340
energy-meters:et340 [2019-01-22 10:16] – external edit 127.0.0.1 | energy-meters:et340 [2019-09-08 17:45] – mvader | ||
====== Energy Meter ET340 manual ====== | ====== Energy Meter ET340 manual ====== | ||
Line 18: | Line 17: | ||
Line 80: | Line 78: | ||
- | ==== 4. Multiple Energy Meters in one system ==== | + | ===== 4. Multiple Energy Meters in one system |
To connect multiple Energy Meters, wire each meter to a separate RS485-USB converter. Which are then each plugged into a separate USB socket on the CCGX. | To connect multiple Energy Meters, wire each meter to a separate RS485-USB converter. Which are then each plugged into a separate USB socket on the CCGX. |
