energy-meters:et340
energy-meters:et340 [2019-01-21 13:13] – [1. Introduction and usage] guy_stewart | energy-meters:et340 [2019-09-08 17:45] – mvader | ||
====== Energy Meter ET340 manual ====== | ====== Energy Meter ET340 manual ====== | ||
Line 18: | Line 17: | ||
Line 80: | Line 78: | ||
- | ==== 4. Multiple Energy Meters in one system ==== | + | ===== 4. Multiple Energy Meters in one system |
To connect multiple Energy Meters, wire each meter to a separate RS485-USB converter. Which are then each plugged into a separate USB socket on the CCGX. | To connect multiple Energy Meters, wire each meter to a separate RS485-USB converter. Which are then each plugged into a separate USB socket on the CCGX. | ||
Connecting multiple ET340 meters to the same RS485-USB cable is not possible: the ET340 meter has no display and its Modbus address can therefor not be changed. | Connecting multiple ET340 meters to the same RS485-USB cable is not possible: the ET340 meter has no display and its Modbus address can therefor not be changed. | ||
+ | ~~DISQUS~~ | ||
