energy-meters:et340
energy-meters:et340 [2019-01-21 11:09] – [DISQUS] ictbeheer | energy-meters:et340 [2019-01-22 10:16] – external edit 127.0.0.1 | ||
Line 8: | Line 8: | ||
This document is the manual for the 3 phase max 65A per phase Energy Meter. | This document is the manual for the 3 phase max 65A per phase Energy Meter. | ||
- | The Energy Meter can be used for four things: | + | The Energy Meter can be used to: |
- Grid meter, and used as control input for an [[assistants: | - Grid meter, and used as control input for an [[assistants: | ||
Line 19: | Line 19: | ||
- | Note that this model is not stocked by Victron Energy, we recommend to purchase it locally. | ||
Line 87: | Line 86: | ||
Connecting multiple ET340 meters to the same RS485-USB cable is not possible: the ET340 meter has no display and its Modbus address can therefor not be changed. | Connecting multiple ET340 meters to the same RS485-USB cable is not possible: the ET340 meter has no display and its Modbus address can therefor not be changed. | ||
+ | ~~DISQUS~~ | ||
