energy-meters:et112
energy-meters:et112 [2019-01-21 01:51] – [Example Diagram] guy_stewart | energy-meters:et112 [2019-01-22 10:16] – external edit 127.0.0.1 | ||
Line 99: | Line 99: | ||
Note 1 You can connect the ET112 in parallel, just need to change the MOD address to another number using the Configuration | Note 1 You can connect the ET112 in parallel, just need to change the MOD address to another number using the Configuration | ||
software from the supplier which is free from Carlo Gavazzi Web site. | software from the supplier which is free from Carlo Gavazzi Web site. | ||
energy-meters/et112.txt · Last modified: 2022-07-15 10:58 by stefanie
