energy-meters:em24
energy-meters:em24 [2019-01-22 10:16] – external edit 127.0.0.1 | energy-meters:em24 [2020-06-27 13:22] – [Option A: wireless Zigbee connection] boekel | ||
Line 43: | Line 43: | ||
=== Single phase dual function === | === Single phase dual function === | ||
- | If you wish to use a three phase meter in a single phase installation to measure the grid on one input and PV inverter output on another phase, use the ET340 instead. See [[energy-meters: | + | If you wish to use a three phase meter in a single phase installation to measure the grid on one input and PV inverter output on another phase, use the ET340 instead. See [[energy-meters: |
If you understand the limitations of this meter in this configuration and wish to proceed anyway, see this diagram - {{ : | If you understand the limitations of this meter in this configuration and wish to proceed anyway, see this diagram - {{ : | ||
Line 76: | Line 76: | ||
Connect the 12V DC power supply to the Zigbee to RS485 converter. When the power is switched on, check the LEDs again. | Connect the 12V DC power supply to the Zigbee to RS485 converter. When the power is switched on, check the LEDs again. | ||
+ | === note on old and new zigbee converters === | ||
+ | Please note that there is a new zigbee converter available now, that is -not- backwards compatible with the old converters. If you have a non compatible set, please ask your supplier for a correct version. | ||
+ | ASS300400100 - Zigbee to RS485 converter partnumber: DRF2619C | ||
+ | ASS300400100 - Zigbee to USB converter | ||
+ | ASS300420100 - Zigbee to RS485 converter partnumber: DRF2659C | ||
+ | ASS300420200 - Zigbee to USB converter | ||
==== Option B: Wired connection to CCGX ==== | ==== Option B: Wired connection to CCGX ==== | ||
