energy-meters:em24
energy-meters:em24 [2019-01-21 11:09] – [DISQUS] ictbeheer | energy-meters:em24 [2019-09-08 17:45] – [2. AC Wiring and front selector] mvader | ||
Line 43: | Line 43: | ||
=== Single phase dual function === | === Single phase dual function === | ||
- | If you wish to use a three phase meter in a single phase installation to measure the grid on one input and PV inverter output on another phase, use the ET340 instead. See [[energy-meters: | + | If you wish to use a three phase meter in a single phase installation to measure the grid on one input and PV inverter output on another phase, use the ET340 instead. See [[energy-meters: |
If you understand the limitations of this meter in this configuration and wish to proceed anyway, see this diagram - {{ : | If you understand the limitations of this meter in this configuration and wish to proceed anyway, see this diagram - {{ : | ||
Line 126: | Line 126: | ||
+ | ~~DISQUS~~ | ||
