energy-meters:em24
energy-meters:em24 [2017-07-19 12:28] – [1. Introduction and usage] mvader | energy-meters:em24 [2019-01-22 10:16] – external edit 127.0.0.1 | ||
Line 7: | Line 7: | ||
This document is the manual for the EM24 three phase max 65 A per phase Energy Meter. As shown in the picture above. | This document is the manual for the EM24 three phase max 65 A per phase Energy Meter. As shown in the picture above. | ||
- | Note that this product is no longer sold. Use the [[energy-meters:et340|ET340]] for new installations. | + | The Energy Meter can be used as a: |
- | https:// | + | |
- Measure the output of a PV Inverter | - Measure the output of a PV Inverter | ||
- (deprecated) < | - (deprecated) < | ||
- | (1) In case the meter is used as a grid meter in a single phase installation, | ||
The meter is connected to the Color Control GX. There are two options in its wiring: | The meter is connected to the Color Control GX. There are two options in its wiring: | ||
Line 24: | Line 18: | ||
+ | If you are wondering which Energy Meter you should use, please read the [[energy-meters: | ||
The REL200100000 is the EM24DINAV93XISX from Carlo Gavazzi. Other EM24 models from Carlo Gavazzi can also be used, as the communication is the same. For example the EM24DINAV53DISX, | The REL200100000 is the EM24DINAV93XISX from Carlo Gavazzi. Other EM24 models from Carlo Gavazzi can also be used, as the communication is the same. For example the EM24DINAV53DISX, | ||
===== 2. AC Wiring and front selector ===== | ===== 2. AC Wiring and front selector ===== | ||
Line 33: | Line 32: | ||
When used to measure a PV Inverter, terminals 1, 4 and 7 should face the PV inverter to ensure correct direction of current and power. | When used to measure a PV Inverter, terminals 1, 4 and 7 should face the PV inverter to ensure correct direction of current and power. | ||
- | === single | + | === Single |
Note the jumper between terminals 1 and 4. You do not need this connection if you have the version AV2 of the sensor: | Note the jumper between terminals 1 and 4. You do not need this connection if you have the version AV2 of the sensor: | ||
Line 42: | Line 41: | ||
To measure a single phase PV inverter in a 3-phase system, connect all 3 phases to the grid phasing terminals (3, 6 and 9). Now you can chose on which phase you want the PV inverter by connecting the L1 line of the PV inverter to terminal 1, 4 or 7. | To measure a single phase PV inverter in a 3-phase system, connect all 3 phases to the grid phasing terminals (3, 6 and 9). Now you can chose on which phase you want the PV inverter by connecting the L1 line of the PV inverter to terminal 1, 4 or 7. | ||
- | In this diagram, | + | If you wish to use a three phase meter in a single phase installation |
- | On the CCGX go to the grid meter in the Wired AC sensor settings. Make sure 'Phase type' is set to ' | + | |
+ | If you understand the limitations of this meter in this configuration and wish to proceed anyway, see this diagram - {{ : | ||
=== Front selector === | === Front selector === | ||
Line 82: | Line 78: | ||
==== Option B: Wired connection to CCGX ==== | ==== Option B: Wired connection to CCGX ==== | ||
- | Connect the Energy Meter to the CCGX using the USB to RS485 cable. The RS485 to USB interface cable between the CCGX and the Energy Meter can be extended up to 100 meters; make sure that the extensions of the Data+ (orange) and Data- (yellow) wires form a twisted pair. | + | Connect the Energy Meter to the CCGX with an USB to RS485 cable (see our price list). The RS485 to USB interface cable between the CCGX and the Energy Meter can be extended up to 100 meters; make sure that the extensions of the Data+ (orange) and Data- (yellow) wires form a twisted pair. |
^ RS485 Converter ^ Energy meter ^ | ^ RS485 Converter ^ Energy meter ^ | ||
Line 125: | Line 121: | ||
Note that only one extra Energy meter can be added: the systems works only with address 1 (the default) and 2. | Note that only one extra Energy meter can be added: the systems works only with address 1 (the default) and 2. | ||
+ | ==== Note on Operation ==== | ||
