drafts:ve-direct-tx-digital-output-cable
Next revisionBoth sides next revision | |||
drafts:ve-direct-tx-digital-output-cable [2016-02-18 12:33] – created john_r | drafts:ve-direct-tx-digital-output-cable [2016-02-18 12:49] – john_r | ||
- | How to add dimming functionality to a solar lighting system | + | ====== |
- | VE.Direct TX digital output cable ASS030550500 (previously called PWM light dimming cable) | + | |
- | To be used together with the MPPT 75/10, 75/15 or 100/15. | + | ===== Cable requirements ===== |
- | This cable is intended for solar lighting applications (more applications may follow later). | + | |
- | Energy consumption can be substantially reduced by light-dimming when appropriate. | + | Use the VE.Direct TX digital output cable ASS030550500 (previously called PWM light dimming cable) |
- | Lower energy consumption will reduce overall system cost, and increase light availability even when | + | |
+ | * This cable is intended for solar lighting applications (more applications may follow later). | ||
the battery has only been partly charged due to bad weather. | the battery has only been partly charged due to bad weather. | ||
The TX cable connects the TX pin on the VE.Direct connector of a MPPT 75/15 or 100/15 to the PWM | The TX cable connects the TX pin on the VE.Direct connector of a MPPT 75/15 or 100/15 to the PWM | ||
light dimming input of a LED driver. | light dimming input of a LED driver. | ||
- | The MPPT solar charge controller must have software version V1.15 or higher. | + | |
- | version can be upgraded with VE Power Setup. The software | + | |
- | http:// | + | ===== Software and firmware requirements ===== |
- | The latest firmware can be requested from service@victronenergy.com | + | |
- | A VE.Direct to USB interface (ASS030530000) is needed to connect to the MPPT controller to the | + | The MPPT solar charge controller must have software version V1.15 or higher. |
+ | version can be upgraded with VE Power Setup which can be downloaded from our website: | ||
+ | [[http:// | ||
+ | The latest firmware can be requested from [[service@victronenergy.com]] | ||
+ | A [[VE.Direct to USB interface]] (ASS030530000) is needed to connect to the MPPT controller to the | ||
computer. | computer. | ||
To configure the MPPT controller, download ‘mpptprefs’: | To configure the MPPT controller, download ‘mpptprefs’: | ||
http:// | http:// |
drafts/ve-direct-tx-digital-output-cable.txt · Last modified: 2019-01-22 10:42 by 127.0.0.1
