drafts:updater-error-codes
drafts:updater-error-codes [2019-09-09 13:23]
evandromr
drafts:updater-error-codes [2019-09-20 11:05]
evandromr
-==== Error codes ==== +==== 9.4 Error codes ====
-In spite of our painstaking efforts, sometimes errors occur. In the following list, you can check possible errors and descriptions.+
 +In spite of our painstaking efforts, sometimes errors occur. But don't worry, it is always possible to recover your product.
 +In most cases, errors are caused by communication problems. Always make sure to check all cable connections and, if you are using Bluetooth, stay as close to the product as possible.
 +Sometimes you may need to [[#bluetooth_smart_-_removing_from_the_list_of_paired_devices|remove the Bluetooth pairing information from your device]] in order to be able to reconnect with your product.
 +In the following list, you can check possible errors and descriptions
 +Check [[#problems_during_firmware_updating|chapter 10.3]] of this manual for Troubleshooting firmware updates. When asking for help, make sure to always mention the error code.
 **VE.Direct products** **VE.Direct products**
Line 10: Line 18:
 | D26             | Updating failed, communication lost. The product might be unusable. Check connection and power supply.\\ Try again and check the product settings once updated. | | D26             | Updating failed, communication lost. The product might be unusable. Check connection and power supply.\\ Try again and check the product settings once updated. |
 | D29             | Could not start updating, the firmware file is corrupt. | | D29             | Could not start updating, the firmware file is corrupt. |
-| D31             | Updating failed, product is unusable. Try again and check the product settings once updated. |+| D31             | Updating failed, the product is unusable. Try again and check the product settings once updated. |
 | D32             | Could not start updating, entering boot mode failed. | | D32             | Could not start updating, entering boot mode failed. |
 | D33             | Could not start updating, the firmware file is not found. | | D33             | Could not start updating, the firmware file is not found. |
-| D90             | Could not start updating, firmware is not for this product. | +| D90             | Could not start updating, the firmware is not for this product. |
-| D91             | Could not start updating, unknown product found. |+| D91             | Could not start updating, an unknown product was found. |
 | D92             | Updating failed, erasing firmware failed. The product might be unusable. Try again and check the product settings once updated. | | D92             | Updating failed, erasing firmware failed. The product might be unusable. Try again and check the product settings once updated. |
 | D93             | Error starting firmware after updating. Power cycle (off/on) your product and if that does not help\\ try updating again, and check the product settings once updated. | | D93             | Error starting firmware after updating. Power cycle (off/on) your product and if that does not help\\ try updating again, and check the product settings once updated. |
-| D94             Could not start updating, error reading configuration. | +| D94             Product updated successfullybut an error occurred reading the previous settings. Check the product settings. |
-| D95             | Product updated successfully, but an error occurred restoring the settings. Check the product settings. | +| D95             | Product updated successfully, but an error occurred restoring the previous settings. Check the product settings. |
-| D96             | Updating failed due to version mis-match. Power cycle (off/on) your product and if that does not help try\\ updating again, and check the product settings once updated. |+| D96             | Updating failed due to version mismatch. Power cycle (off/on) your product and if that does not help try\\ updating again, and check the product settings once updated. |
 | D97             | Dup executable too old. | | D97             | Dup executable too old. |
 | D98             | Firmware file is not a valid dup file. | | D98             | Firmware file is not a valid dup file. |
Line 37: Line 45:
 | B9 | Timeout waiting for access to the Dfu BLE service. | | B9 | Timeout waiting for access to the Dfu BLE service. |
 | B10 | Timeout waiting for a response. | | B10 | Timeout waiting for a response. |
-| B11 | Timeout while writing to the product. Perhaps a pairing dialog is shown? Please retry. |+| B11 | Timeout while writing to the product. Perhaps a pairing dialogue is shown? Please retry. |
 +| B12 | Device was no longer found. Perhaps out of range? Please retry. |
 | B96 | An internal error occurred (Opcode not supported). Please send a service report to Victron Energy. | | B96 | An internal error occurred (Opcode not supported). Please send a service report to Victron Energy. |
 | B97 | The requested encryption is not supported by the product. Please send a service report to Victron Energy. | | B97 | The requested encryption is not supported by the product. Please send a service report to Victron Energy. |
Line 46: Line 55:
 | B102 | An internal error occurred (Not allowed). Please send a service report to Victron Energy. | | B102 | An internal error occurred (Not allowed). Please send a service report to Victron Energy. |
-** XUP files **+** VE.Bus Products **
 +^Error ^Description^
 +|V2  | No product detected. Please check all the cable connections and try again.|
 +|V3  | An unexpected timeout was triggered. Please check all the cable connections and try again.|
 +|V4  | Incomplete vff file. Nonce missing. Please make sure you selected a valid update file and try again.|
 +|V5  | Incomplete vff file. EEPROM lines missing. Please make sure you selected a valid update file and try again.|
 +|V6  | The vff file contains more eeprom data than supported. Please make sure you selected a valid update file and try again.|
 +|V7  | The calibration map in the file exceeds the device calibration map. Please make sure you selected a valid update file and try again.|
 +|V8  | Device calibration data size bigger than expected. Please make sure you selected a valid update file and try again.|
 +|V9  | Bootloader did not respond to bootloader setup. Please check all the cable connections and try again.|
 +|V10 | Bootloader response to version request failed.|
 +|V11 | Incompatible bootblock. Function version invalid.|
 +|V12 | Incompatible bootblock. Version invalid.|
 +|V13 | Bootloader did not start after bootblock update.|
 +|V14 | Incompatible bootblock type.|
 +|V15 | No or unexpected response to target id query.|
 +|V16 | No or unexpected response to eeprom read action.|
 +|V17 | No or unexpected response to calibration map query.|
 +|V18 | The supplied firmware contains new unsupported calibration values. \\ The updater does not know how to handle them.|
 +|V19 | No response received to eeprom write command. Please check all the cable connections and try again.|
 +|V20 | Invalid response received to eeprom write command. Please check all the cable connections and try again.|
 +|V21 | No response received to code write command. Please check all the cable connections and try again.|
 +|V22 | Invalid response received to code write command.|
 +|V23 | The MK2/MK3 did not respond. Please check all the cable connections and try again.|
 +|V24 | The connected product does not match the specified model in the file. \\ Please make sure you selected a valid update file and try again.|
 +|V25 | The hardware revision specific eeprom defaults data is corrupt. \\ Please make sure you selected a valid update file and try again.|
 +|V26 | Updates can not be performed with a VEBUS BMS connected.|
 +|V27 | Updates can not be performed with a DMC connected.|
 +|V40 | Failed to start Update. could not allocate memory. Malloc error.|
 +|V50 | Failed to start Update. File open error. Please check the file location and access permissions.\\ Make sure you selected a valid update file and try again.|
 +|V51 | Failed to start Update. File write error. Please check file location and access permissions.\\ Make sure you selected a valid update file and try again.|
 +|V52 | Failed to start Update. File read error. Please check file location and access permissions.\\ Make sure you selected a valid update file and try again.|
 +|V53 | Failed to start Update. File checksum error. File corrupted or not a valid VFF file.\\ Please make sure you selected a valid update file and try again.|
 +|V54 | Failed to start Update. File has an incompatible version number.\\ Please make sure you selected a valid update file and try again.|
 +|V55 | Failed to start Update. File section not found. File corrupted or not a valid VFF file.\\ Please make sure you selected a valid update file and try again.|
 +|V56 | Failed to start Update. Format error. File corrupted or not a valid VFF file.\\ Please make sure you selected a valid update file and try again.|
 +** All other products (XUP update files)**
 ^Error ^Description^ ^Error ^Description^
-|X1 |Successful|
-|X2 |Generic Failure. Please try again.|
 |X3 |Invalid updater state. Please try again.| |X3 |Invalid updater state. Please try again.|
 |X4 |Firmware not for Product (Id). Please make sure you selected a valid update file and try again.| |X4 |Firmware not for Product (Id). Please make sure you selected a valid update file and try again.|
-|X5 |Updater (version) too old.") }+|X5 |Updater (version) too old. |
 |X6 |Communication Error. No Callback handler connected. Please check the connection and try again.| |X6 |Communication Error. No Callback handler connected. Please check the connection and try again.|
-|X7 |Communication Error. Vreg ack-ed with unexpected error.  Please check the connection and try again.|+|X7 |Communication Error. Vreg ack-ed with an unexpected error.  Please check the connection and try again.|
 |X8 |Update (xup) file format not supported. Please make sure you selected a valid update file and try again.| |X8 |Update (xup) file format not supported. Please make sure you selected a valid update file and try again.|
-|X9 |File Error. No Instance Blob could be found in update file. Please make sure you selected a valid update file and try again.|+|X9 |File Error. No Instance Blob could be found in the update file. Please make sure you selected a valid update file and try again.|
 |X10 |File Error. Invalid instance Blob attribute. Please make sure you selected a valid update file and try again.| |X10 |File Error. Invalid instance Blob attribute. Please make sure you selected a valid update file and try again.|
 |X11 |File Error. Instance Blob defined more than once. Please make sure you selected a valid update file and try again.| |X11 |File Error. Instance Blob defined more than once. Please make sure you selected a valid update file and try again.|
-|X12 |File Error. No Firmware Version for instance found in update file. Please make sure you selected a valid update file and try again.|+|X12 |File Error. No Firmware Version for instance found in the update file. Please make sure you selected a valid update file and try again.|
 |X13 |Communication Error. Unexpected Vreg Ack received. Please check the connection and try again.| |X13 |Communication Error. Unexpected Vreg Ack received. Please check the connection and try again.|
-|X14 |Communication Error. Instance could not be reached. Please check the connection and try again.|+|X14 |Communication Error. The instance could not be reached. Please check the connection and try again.|
 |X15 |Fail on Minimum Firmware Version check. Please make sure you selected a valid update file and try again.| |X15 |Fail on Minimum Firmware Version check. Please make sure you selected a valid update file and try again.|
 |X16 |Failed to Begin Update. Please check the connection and try again.| |X16 |Failed to Begin Update. Please check the connection and try again.|
-|X17 |File Error. No/invalid Firmware data found for instance in update file. Please make sure you selected a valid update file and try again.|+|X17 |File Error. No/invalid Firmware data found for instance in the update file. Please make sure you selected a valid update file and try again.|
 |X18 |Update Error. Invalid ack on non-final Update Data. Please check the connection and try again.| |X18 |Update Error. Invalid ack on non-final Update Data. Please check the connection and try again.|
 |X19 |Update Error. Invalid sequence# in Update Data Ack. Please check the connection and try again.| |X19 |Update Error. Invalid sequence# in Update Data Ack. Please check the connection and try again.|
Line 73: Line 118:
 |X24 |Verification Error. Invalid instance field in Minimum Firmware Version Ack. Please check the connection and try again.| |X24 |Verification Error. Invalid instance field in Minimum Firmware Version Ack. Please check the connection and try again.|
 |X25 |Verification Error. Invalid instance field in Firmware Version Ack. Please check the connection and try again.| |X25 |Verification Error. Invalid instance field in Firmware Version Ack. Please check the connection and try again.|
-|X26 |Verification Error. Invalid instance field in UDF Version Ack. Please check the connection and try again.| +|X26 |Verification Error. Invalid instance field in UDF Version Ack.\\ Please check the connection and try again.|
-|X27 |Failed to verify Minimum Firmware Version. Please check the connection and try again.|+|X27 |Failed to verify Minimum Firmware Version.\\ Please check the connection and try again.|
 |X28 |Failed to verify Firmware Version. Please check the connection and try again.| |X28 |Failed to verify Firmware Version. Please check the connection and try again.|
 |X29 |Failed to verify UDF Version. Please check the connection and try again.| |X29 |Failed to verify UDF Version. Please check the connection and try again.|
 |X30 |Failed on Minimum Firmware Version verification. Please check the connection and try again.| |X30 |Failed on Minimum Firmware Version verification. Please check the connection and try again.|
 |X31 |Failed on Firmware Version verification. Please check the connection and try again.| |X31 |Failed on Firmware Version verification. Please check the connection and try again.|
-|X32 |Still in Bootloader Mode after update. Please try again.| +|X32 |Still in Bootloader Mode after the update. Please try again.|
-|X33 |File Error. No Product Id found in update file. Please make sure you selected a valid update file and try again.| +|X33 |File Error. No Product Id found in the update file. Please make sure you selected a valid update file and try again.|
-|X34 |File Error. No VE.Direct baudrates found in update file. Please make sure you selected a valid update file and try again.| +|X34 |File Error. No VE.Direct baudrates found in the update file. Please make sure you selected a valid update file and try again.|
-|X35 |File Error. No Xup Format Version found in update file. Please make sure you selected a valid update file and try again.| +|X35 |File Error. No Xup Format Version found in the update file. Please make sure you selected a valid update file and try again.|
-|X36 |File Error. No Minimum Updater Version found in update file. Please make sure you selected a valid update file and try again.| +|X36 |File Error. No Minimum Updater Version found in the update file. Please make sure you selected a valid update file and try again.|
-|X37 |File Error. No Firmware (product) Version found in update file. Please make sure you selected a valid update file and try again.| +|X37 |File Error. No Firmware (product) Version found in the update file. Please make sure you selected a valid update file and try again.|
-|X38 |File Error. Update file does not match XML standard. Please make sure you selected a valid update file and try again.|+|X38 |File Error. The update file does not match XML standard. Please make sure you selected a valid update file and try again.|
 |X39 |Communication Error. Vreg Ack timeout. Please check the connection and try again.| |X39 |Communication Error. Vreg Ack timeout. Please check the connection and try again.|
 |X40 |Communication Error. No product found. Please check the connection and try again.| |X40 |Communication Error. No product found. Please check the connection and try again.|
Line 94: Line 139:
 |X45 |Update Error. Vreg Ack error: Invalid instance. Please check the connection and try again.| |X45 |Update Error. Vreg Ack error: Invalid instance. Please check the connection and try again.|
 |X46 |Update Error. Vreg Ack error. Please check the connection and try again.| |X46 |Update Error. Vreg Ack error. Please check the connection and try again.|
drafts/updater-error-codes.txt · Last modified: 2019-09-20 11:05 by evandromr
