drafts:sa_system:dcsolar1600
DC-solar 1600VA / 12 volt
Parts
- EasySolar 12/1600/70-16 MPPT 100/50 Inv./Solar Charger Combi: CEP121621000
- Batteries: 2 pieces 12V/220Ah AGM Deep Cycle Battery: BAT412201080
- or 2 pieces 12V/220Ah Gel Deep Cycle Battery: BAT412201100
- Battery Monitor BMV700: BAM010700000
Nieuw plaatje
optional
- Digital Multi Control 200/200A GX (90º RJ45) Retail: DMC000200000R
- Color Control GX Retail: BPP000300100R
nieuw plaatje
How long is the backup time?
Explain what it solves:
- Load shedding period: High power 1000W DoD 50% SoC about 2 hours
- At night: Low power 250W DoD 50% SoC about 8 hours
Notes for batteries:
- We recommend deep-cycle GEL or AGM batteries. At least 200Ah per block.
- Cable cross section: xxxx mm2 MCO: welke mm2 / stroom rating welke lengte
VE.Configure Settings
plaatjes toevoegen!!
- Disable overrule by remote
- Change DC input low shutdown to 10.8 volts
- Change DC input low restart to 11.8 volts
- Change DC input low pre-alarm to ??.? volts
- Charge current can be left at standard setting.
- Enable battery monitor and set correct Battery capacity
drafts/sa_system/dcsolar1600.1548148578.txt.gz · Last modified: by 127.0.0.1
