drafts:sa_system:dcsolar1600
| drafts:sa_system:dcsolar1600 [2019-01-21 11:02] – [DISQUS Comments] ictbeheer | drafts:sa_system:dcsolar1600 [2019-08-29 16:12] (current) – removed mvader | ||
| Line 1: | Line 1: | ||
| - | ====== DC-solar 1600VA / 12 volt ====== | ||
| - | === Parts === | ||
| - | * EasySolar 12/ | ||
| - | * Batteries: 2 pieces 12V/220Ah AGM Deep Cycle Battery: BAT412201080 | ||
| - | * or 2 pieces 12V/220Ah Gel Deep Cycle Battery: BAT412201100 | ||
| - | * Battery Monitor BMV700: BAM010700000 | ||
| - | Nieuw plaatje | ||
| - | === optional === | ||
| - | * Digital Multi Control 200/200A GX (90º RJ45) Retail: DMC000200000R | ||
| - | * Color Control GX Retail: BPP000300100R | ||
| - | nieuw plaatje | ||
| - | == How long is the backup time? == | ||
| - | Explain what it solves: | ||
| - | * Load shedding period: High power 1000W DoD 50% SoC about 2 hours | ||
| - | * At night: Low power 250W DoD 50% SoC about 8 hours | ||
| - | == Notes for batteries: == | ||
| - | * We recommend deep-cycle GEL or AGM batteries. At least 200Ah per block. | ||
| - | * Cable cross section: xxxx mm2 MCO: welke mm2 / stroom rating welke lengte | ||
| - | == VE.Configure Settings == | ||
| - | plaatjes toevoegen!! | ||
| - | * Disable overrule by remote | ||
| - | * Change DC input low shutdown to 10.8 volts | ||
| - | * Change DC input low restart to 11.8 volts | ||
| - | * Change DC input low pre-alarm to ??.? volts | ||
| - | * Charge current can be left at standard setting. | ||
| - | * Enable battery monitor and set correct Battery capacity | ||
drafts/sa_system/dcsolar1600.1548064934.txt.gz · Last modified: by ictbeheer
