drafts:sa_system:dcsolar1600-mp
drafts:sa_system:dcsolar1600-mp [2015-04-03 15:12] – martijncoster | drafts:sa_system:dcsolar1600-mp [2019-08-29 16:11] (current) – removed mvader | ||
- | ====== MultiPlus DC-Solar 1600VA / 12 volt ====== | ||
- | === Introduction === | ||
- | Short story | ||
- | === Parts === | ||
- | * 1x - CMP121620000 - [[http:// | ||
- | * 1x - SCC010050200 - [[http:// | ||
- | * 1x - BAM010700000 - [[http:// | ||
- | * 2x - BAT412201080 - [[http:// | ||
- | * or - BAT412201100 - [[http:// | ||
- | * 2x - Battery link cables | ||
- | === optional === | ||
- | * DMC000200000R - Digital Multi Control 200/200A GX (90º RJ45) Retail | ||
- | * BPP000300100R - Color Control GX Retail | ||
- | == How long is the backup time? == | ||
- | Explain what it solves: | ||
- | * Load shedding period: High power 1000W DoD 50% SoC about 2 hours | ||
- | * At night: Low power 250W DoD 50% SoC about 8 hours | ||
- | == Notes for batteries: == | ||
- | * We recommend deep-cycle GEL or AGM batteries. At least 200Ah per block. | ||
- | * Cable cross section: xxxx mm2 MCO: welke mm2 / stroom rating welke lengte | ||
- | == VE.Configure Settings == | ||
- | plaatjes toevoegen!! \\ | ||
- | [[http:// | ||
- | [[http:// | ||
- | settings: | ||
- | * Disable overrule by remote | ||
- | * Change DC input low shutdown to 10.8 volts | ||
- | * Change DC input low restart to 11.8 volts | ||
- | * Change DC input low pre-alarm to ??.? volts | ||
- | * Charge current can be left at standard setting. | ||
- | * Enable battery monitor and set correct Battery capacity | ||
- | ~~DISQUS~~ | ||
drafts/sa_system/dcsolar1600-mp.1428066748.txt.gz · Last modified: 2015-04-03 15:12 by martijncoster
