drafts:sa_system:backup1600-mp
drafts:sa_system:backup1600-mp [2015-04-03 12:35] – martijncosterdrafts:sa_system:backup1600-mp [2019-08-29 16:11] (current) – removed mvader
-====== MultiPlus Backup only 1600VA / 12 volt ======
-=== Introduction ===
-Short story
-=== Parts ===
-  * 1x - CMP121620000 - [[http://www.victronenergy.com/inverters-chargers/MultiPlus-12v-24v-48v-800va-3kva#datasheet|MultiPlus Compact 12/1600/70-16 230V VE.Bus Inverter/Charger]]
-  * 2x - BAT412201080 - [[http://www.victronenergy.com/batteries/Gel-and-AGM-batteries|12V/220Ah AGM Deep Cycle Battery ]]
-  * or - BAT412201100 - [[http://www.victronenergy.com/batteries/Gel-and-AGM-batteries|12V/220Ah Gel Deep Cycle Battery]]
-  * 2x - Battery link cables
-{{ :drafts:sa_system:1600w multiplus-simple.jpg?nolink&500 |}}
-=== optional ===
-  * DMC000200000R - Digital Multi Control 200/200A GX (90º RJ45) Retail
-  * BPP000300100R - Color Control GX Retail
-{{ :drafts:sa_system:1600w multiplus-option.jpg?nolink&700 |}}
-== How long is the backup time? ==
-Explain what it solves:
-  * Load shedding period: High power 1000W DoD 50% SoC about 2 hours
-  * At night: Low power 250W DoD 50% SoC about 8 hours
-== Notes for batteries: ==
-  * We recommend deep-cycle GEL or AGM batteries. At least 200Ah per block.
-  * Cable cross section: xxxx mm2  MCO: welke mm2 / stroom rating welke lengte
-== VE.Configure Settings ==
-plaatjes toevoegen!! \\
-[[http://www.victronenergy.com/support-and-downloads/software|software download VE.Configure]] \\
-[[http://www.victronenergy.com/live/updating_firmware:updating_ve.bus_products|Updating VE.Bus products]] \\
-settings:
-  * Disable overrule by remote
-  * Change DC input low shutdown to 10.8 volts
-  * Change DC input low restart to 11.8 volts
-  * Change DC input low pre-alarm to ??.? volts
-  * Charge current can be left at standard setting.
-  * Enable battery monitor and set correct Battery capacity
-{{ :drafts:sa_system:veconf-inv.jpg?nolink&440|}}
-{{ :drafts:sa_system:veconf-batmon.jpg?nolink&430 |}}
-===== DISQUS Comments =====
-~~DISQUS~~
drafts/sa_system/backup1600-mp.1428057325.txt.gz · Last modified: by martijncoster
