drafts:pylontest
drafts:pylontest [2018-12-24 11:22] – guy_stewart | drafts:pylontest [2020-06-30 13:11] (current) – removed mvader | ||
- | ====== Victron & Pylontech ===== | ||
- | The combination of Victron products with Pylontech lithium batteries has been tested and certified by the Victron and Pylontech R&D departments. | ||
- | This manual is intended to be used in conjunction with the product manual supplied by Pylontech. It provides additional and specific information regarding integration with Victron systems. | ||
- | The Pylontech includes a Battery Management System (BMS) with each battery cell module. This interfaces with the Victron [[venus-os: | ||
- | ===== 1. Product & system compatibility ===== | ||
- | ^ Battery ^ US2000B ^ US2000B Plus ^ US3000 Plus ^ | ||
- | | Module capacity| | ||
- | === 1.1 Offgrid, Backup and Energy Storage Systems are possible === | ||
- | Victron + Pylontech can be used for the following system types: | ||
- | * Energy Storage Systems - Self Consumption ([[ess: | ||
- | * Grid Backup | ||
- | * Off-grid | ||
- | === 1.2 A Venus-device is required, either Color Control GX (CCGX) or Venus GX (VGX) === | ||
- | It is essential to use the CAN-bus connection of the [[venus-os: | ||
- | The minimum required firmware version for the [[https:// | ||
- | In grid connected systems, advanced control functions are configurable in the ESS settings on the [[venus-os: | ||
- | In off-grid systems, the control functions of the Pylontech Battery Management System (BMS) are built into the latest version of the [[venus-os: | ||
- | === 1.3 All 48V Multi, MultiPlus, MultiGrid and Quattro are compatible === | ||
- | The minimum firmware version is 422. Though updating to the latest firmware is recommended where possible. | ||
- | These inverter/ | ||
- | === 1.4 All 48V VE.direct BlueSolar and SmartSolar MPPT Chargers are compatible === | ||
- | For proper operation, the Pylontech battery needs to be able to control the charge current. Therefor it is recommended to use Victron 48V compatible MPPTs models with VE.Direct port for charging. | ||
- | __MPPTs with a VE.Direct port__ | ||
- | MPPTs are controlled via the [[venus-os: | ||
- | The MPPT requires connection to the [[venus-os: | ||
- | To test operation, try disconnecting the [[venus-os: | ||
- | __MPPTs with a VE.Can port__ | ||
- | Use of VE.Can MPPT's with Pylontech batteries is not supported or documented. | ||
- | ==== 1.6 Minimum Battery Sizing Recommendations | ||
- | Each US2000B Plus battery module is approximately 50Ah at 48V, can provide 25A continuous charge and discharge and 100A peak for 1 minute. | ||
- | The charge and discharge rates are managed automatically by the Pylontech battery and [[venus-os: | ||
- | Using very large solar arrays with battery banks that are too small can exceed the limits of the batteries ability to charge and possibly lead to the BMS triggering over-current alarms. | ||
- | You must have the minimum number of units to supply the potential current demand of the load connected to the inverter. It is more desirable to have the inverter/ | ||
- | Some suggested battery sizings for common Victron inverter/ | ||
- | ^ Inverter / Charger Model ^ Inv continuous watts @ 25 degrees ^ Inverter peak watts surge rating ^ Number of Pylontech modules ^ Battery continuous discharge watt rating ^ Battery peak discharge watt rating ^ | ||
- | | Multiplus 48/500/6 | 430 | 900 | 1 | 1200 | 4800 | | ||
- | | Multiplus 48/800/9 | 700 | 1600 | 1 | 1200 | 4800 | | ||
- | | Multiplus 48/1200/13 | 1000 | 2400 | 1 | 1200 | 4800 | | ||
- | | Multiplus 48/3000/35 | 2400 | 6000 | 2 | 2400 | 9600 | | ||
- | | Multiplus 48/5000/70 | 4000 | 10000 | 4 | 4800 | 19200 | | ||
- | | Quattro 48/ | ||
- | ==== 2. Wiring of CAN-bus cable between B-Box and Venus-device ==== | ||
- | Use the //VE.Can to CAN-bus BMS type B Cable//, part number ASS030720018. Plug the side which is labeled Battery BMS into the Pylontech CAN port. Plug the side labeled Victron VE.Can into the [[venus-os: | ||
- | More information about the cable can be found in [[battery_compatibility: | ||
- | Without properly connecting this cable, the battery will not show up on the display of the [[venus-os: | ||
- | It is important to ensure this connection and display of the battery on the [[venus-os: | ||
- | ==== 4. VEConfigure settings ==== | ||
- | This section presumes familiarity with [[https:// | ||
- | === 4.1 General tab === | ||
- | * Check the " | ||
- | * Set the battery capacity to the total capacity of the battery: eg 50Ah times the number of battery modules for the 2000B Plus model. | ||
- | * The other parameters (" | ||
- | === 4.2 Charge parameters === | ||
- | === Charger tab === | ||
- | ^ Parameter | ||
- | | Battery type | Lithium | | ||
- | | Charge curve | Fixed | ||
- | | Absorption voltage | ||
- | | Float voltage | ||
- | | Absorption time | 1 Hr | | ||
- | Note: make sure to double check the float voltage after completing Assistants, and if necessary set it back to 53.0 V. | ||
- | === Option A: ESS Assistant === | ||
- | If you are using the battery as part of a grid connected ESS system - run the ESS Assistant in VEConfigure. | ||
- | Select the externally managed Lithium battery option | ||
- | ^ ESS Parameter ^ Settings ^ | ||
- | |Sustain voltage. | ||
- | |Dynamic cut-off values | set all values to 46V.| | ||
- | |Restart offset: | ||
- | === Option B: Off-grid system using CAN-bus cable. ==== | ||
- | You will need the latest firmware on all connected devices. | ||
- | On the [[venus-os: | ||
- | ^Venus Settings -> System Setup Parameter ^ Value ^ | ||
- | |DVCC|ON| | ||
- | |Shared Voltage Sense |OFF| | ||
- | In the Inverter tab of VEConfigure | ||
- | ^VEConfigure Inverter Parameter | ||
- | |DC input low shut-down | 47V| | ||
- | |DC input low restart | ||
- | |DC input low pre-alarm* | 51V| | ||
- | * The pre-alarm setting is dependant on your preference and on site specific requirements. You may wish for this to be activated earlier in an off grid situation to allow time to start a backup generator. If the system is configured in ESS mode, you may not wish to have this alarm trigger until below the Sustain threshold voltage, as this system is in no danger normally and will ' | ||
- | === Hardware Protection Points === | ||
- | In normal operation, the charge parameter limits are set by the Pylontech battery and communicated through the system by the [[venus-os: | ||
- | * Low Voltage: When the battery discharges to 44.5V or less, battery protection will turn on. | ||
- | * High Voltage: If charging voltage above 54V, battery protection will turn on. | ||
- | * Working discharge temperature range is from -10 to 50 degrees celsius. | ||
- | * Charging temperature range is from 0 to 50 degrees celsius. | ||
- | If operation is attempted outside the operating range, the battery will disconnect to protect itself. | ||
- | ==== 5. Venus-device Configuration ==== | ||
- | * Select the //CAN-bus BMS (500 kbit/s)// CAN-profile in the CCGX. Menu path: //Settings -> Services -> CAN-profile// | ||
- | * After properly wiring and setting up, the Pylontech will be visible as a battery in the device list: | ||
- | * The parameters option within the battery page shows the actual battery charge and discharge limits | ||
- | This parameters page is also a good place to check that all batteries are connected and working properly. In normal working conditions, the current limit is 25A per cell. For example, 100A charge current limit ( 100 / 25 = 4 ) means there are 4 Pylontech battery modules connected. | ||
- | ===== 6. Configure VE-Direct MPPT ===== | ||
- | In normal operation the MPPT charge characteristics are governed by the [[venus-os: | ||
- | This section presumes familiarity with [[victronconnect: | ||
- | The settings below are a precautionary measure. | ||
- | ^MPPT Parameter ^ Setting ^ | ||
- | |Battery voltage. | ||
- | |Absorption voltage | ||
- | ===== 7. Example Wiring Diagram ===== | ||
- | ===== 8. Troubleshooting ===== | ||
- | If the system is not operating correctly, go through these steps. | ||
- | === Step 0. If the Inverter/ | ||
- | As a safety precaution, the inverter/ | ||
- | === Step 1. Check that the Pylontech battery is visible on the Venus-device list === | ||
- | If its not visible, check: | ||
- | * [[venus-os: | ||
- | * CAN-bus communication cabling between Pylontech and Victron system. Make sure that it is in the right way around. | ||
- | * Pylontech system is up and running (leds are) | ||
- | === Step 2. Check that the Pylontech battery is ready for use === | ||
- | Check the Max Charge Voltage parameter. This voltage parameter is sent, together with the other three parameters, | ||
- | ===== 11. Further Information ===== | ||
- | For information about where to buy or find suitably qualified installers, visit the [[https:// | ||
- | Further community discussion about installing and using Pylontech and Victron can found at [[https:// |
drafts/pylontest.1545646937.txt.gz · Last modified: 2018-12-24 11:22 by guy_stewart
