drafts:mppt_faq
drafts:mppt_faq [2019-06-05 13:59] – [Q8: Can I connect different panels to the same charge controller?] mvaderdrafts:mppt_faq [2021-09-30 05:18] (current) – guystewart
 ====== MPPT FAQ ====== ====== MPPT FAQ ======
-See also [[victronconnect:mppt-solarchargers|]].
 ==== Q1: I want to size or oversize my PV array, how can I do this? ==== ==== Q1: I want to size or oversize my PV array, how can I do this? ====
Line 9: Line 8:
 By default the RX pin is already used to control the battery life on/off selection with the jumper. Use VictronConnect to change the function of the RX pin to remote on/off to enable BMS control. See By default the RX pin is already used to control the battery life on/off selection with the jumper. Use VictronConnect to change the function of the RX pin to remote on/off to enable BMS control. See
-[[https://www.victronenergy.com/live/victronconnect:mppt-solarchargers#rx_port_function]] for details.+[[https://www.victronenergy.com/media/pg/Manual_SmartSolar_MPPT_100-30__100-50/en/configuration-and-settings.html#UUID-b6cabb55-8d14-4fc9-190f-c0856aab60d3]] for details.
 ==== Q3: My MPPT is only showing voltage readings, not currents and also no Watts? ==== ==== Q3: My MPPT is only showing voltage readings, not currents and also no Watts? ====
drafts/mppt_faq.1559743176.txt.gz · Last modified: by mvader
