drafts:mppt_faq
drafts:mppt_faq [2019-03-06 12:04] – [Q7: Can I use the MPPT Solar Charger as DC-DC charger?] bob | drafts:mppt_faq [2021-09-30 07:18] (current) – guystewart | ||
====== MPPT FAQ ====== | ====== MPPT FAQ ====== | ||
- | See also [[victronconnect: | ||
==== Q1: I want to size or oversize my PV array, how can I do this? ==== | ==== Q1: I want to size or oversize my PV array, how can I do this? ==== | ||
Line 9: | Line 8: | ||
By default the RX pin is already used to control the battery life on/off selection with the jumper. Use VictronConnect to change the function of the RX pin to remote on/off to enable BMS control. See | By default the RX pin is already used to control the battery life on/off selection with the jumper. Use VictronConnect to change the function of the RX pin to remote on/off to enable BMS control. See | ||
- | [[https:// | + | [[https:// |
==== Q3: My MPPT is only showing voltage readings, not currents and also no Watts? ==== | ==== Q3: My MPPT is only showing voltage readings, not currents and also no Watts? ==== | ||
Line 51: | Line 50: | ||
No. Under no circumstances. | No. Under no circumstances. | ||
+ | ==== Q9: Can I use panels with optimisers? ==== | ||
+ | No. | ||
drafts/mppt_faq.txt · Last modified: 2021-09-30 07:18 by guystewart
