drafts:mppt_faq
drafts:mppt_faq [2019-01-21 11:08] – [DISQUS Comments] ictbeheer | drafts:mppt_faq [2019-06-05 15:59] – [Q8: Can I connect different panels to the same charge controller?] mvader | ||
Line 45: | Line 45: | ||
For example to charge a 12 Volt battery from a 24V battery bank? | For example to charge a 12 Volt battery from a 24V battery bank? | ||
- | Yes. | + | No. |
==== Q8: Can I connect different panels to the same charge controller? ==== | ==== Q8: Can I connect different panels to the same charge controller? ==== | ||
Line 51: | Line 51: | ||
No. Under no circumstances. | No. Under no circumstances. | ||
+ | ==== Q9: Can I use panels with optimisers? ==== | ||
+ | No. | ||
+ | ~~DISQUS~~ | ||
drafts/mppt_faq.txt · Last modified: 2021-09-30 07:18 by guystewart
