drafts:mppt_faq
drafts:mppt_faq [2017-07-24 20:26] – [My MPPT is only showing voltages, not currents and also no Watts?] mvader | drafts:mppt_faq [2019-06-05 15:59] – [Q8: Can I connect different panels to the same charge controller?] mvader | ||
====== MPPT FAQ ====== | ====== MPPT FAQ ====== | ||
- | ==== 75/15 and 100/15 cannot be controlled by a BMS, what now? ==== | + | See also [[victronconnect: |
+ | ==== Q1: I want to size or oversize my PV array, how can I do this? ==== | ||
- | The reason is that the RX pin is already used to the battery life on/off selection with the jumper. So therefore it is unfortunately not possible to control these two models with the VE.Direct .. remote on/off cable [link]. The solutions is buy the next model in line: the MPPT 100/30. | + | See the blogpost [[https://www.victronenergy.com/blog/ |
- | ==== My MPPT is only showing voltage readings, not currents and also no Watts? ==== | + | ==== Q2: 75/10, 75/15 and 100/15 cannot be controlled by a BMS, what now? ==== |
+ | By default the RX pin is already used to control the battery life on/off selection with the jumper. Use VictronConnect to change the function of the RX pin to remote on/off to enable BMS control. See | ||
+ | ==== Q3: My MPPT is only showing voltage readings, not currents and also no Watts? ==== | ||
Make sure to *not* connect PV minus to the battery. See the manual. | Make sure to *not* connect PV minus to the battery. See the manual. | ||
- | ==== Can the output of the MPPT be used as a power supply, thus without batteries? ==== | + | ==== Q4: Can the output of the MPPT be used as a power supply, thus without batteries? ==== |
The answer is; it depends on the type of load. | The answer is; it depends on the type of load. | ||
Line 16: | Line 22: | ||
Loads where under voltage does not apply, like light globes, can be operated without any problems. | Loads where under voltage does not apply, like light globes, can be operated without any problems. | ||
- | ==== I want to over dimension | + | ==== Q5: What about grounding one of the PV array poles? ==== |
+ | The MPPT is non isolated, meaning that the minus of the PV input is at the same potential as the minus of the battery output. | ||
+ | Grounding is always done at one point only, to avoid ground currents. For a battery system, grounding must be done at the battery. | ||
+ | ==== Q6: The Solar Charger is not working | ||
- | Over-dimensioning a PV array is installing more Watt-peak than the maximum charge power of the chosen MPPT charge controller. A common reason to over dimension is to cater for winter time. | + | 1. Check that the PV voltage |
- | How to determine how far you can over dimension | + | Or measure the voltage with a Volt meter. Make sure to measure the voltage on the terminals on the charger. Not elsewhere, to rule out any faulty wires or fuses. The panel voltage needs to be at least 5V above the battery voltage for the charger |
- | There are two limits, when determining the maximum array size that can be connected | + | 2. For models with a Remote on/off switch (a green two pole connector, labelled Remote L H), check that the jumper is in. L and H need to be shorted for the unit to switch on. Only the large models have this connector, see datasheet for details. |
- | - The Maximum PV open circuit | + | 3. Check that the battery |
- | - The Maximum PV short circuit current (Isc at STC) | + | |
- | Both values are specified in the datasheets of all our MPPT Solar Chargers. Those two ratings of the PV array must not exceed these MPPT limits. | + | 4. Check for [[: |
- | Note that these two maximum ratings must **not** be multiplied | + | If all above is fine, and still the unit does not operate, contact a dealer |
+ | ==== Q7: Can I use the MPPT Solar Charger as DC-DC charger? ==== | ||
- | === Determining the maximum PV open circuit voltage === | + | For example |
- | First look on the datasheets of the solar panels | + | |
- | === Determining the maximum PV short circuit current === | + | No. |
- | Get the maximum PV short circuit current from the PV Panel datasheet. Multiply by the number of panels in parallel in the array. Having more panels in series does not change the number. | + | |
- | The result of the calculation may not exceed the Max PV short circuit current as specified on the MPPT Datasheet. | + | ==== Q8: Can I connect different panels to the same charge controller? ==== |
+ | No. Under no circumstances. | ||
- | ===== DISQUS Comments ===== | + | ==== Q9: Can I use panels with optimisers? |
+ | No. | ||
drafts/mppt_faq.txt · Last modified: 2021-09-30 07:18 by guystewart
