drafts:mppt_faq
drafts:mppt_faq [2019-06-05 15:59] – [Q8: Can I connect different panels to the same charge controller?] mvader | drafts:mppt_faq [2021-09-30 07:18] (current) – guystewart | ||
====== MPPT FAQ ====== | ====== MPPT FAQ ====== | ||
- | See also [[victronconnect: | ||
==== Q1: I want to size or oversize my PV array, how can I do this? ==== | ==== Q1: I want to size or oversize my PV array, how can I do this? ==== | ||
Line 9: | Line 8: | ||
By default the RX pin is already used to control the battery life on/off selection with the jumper. Use VictronConnect to change the function of the RX pin to remote on/off to enable BMS control. See | By default the RX pin is already used to control the battery life on/off selection with the jumper. Use VictronConnect to change the function of the RX pin to remote on/off to enable BMS control. See | ||
- | [[https:// | + | [[https:// |
==== Q3: My MPPT is only showing voltage readings, not currents and also no Watts? ==== | ==== Q3: My MPPT is only showing voltage readings, not currents and also no Watts? ==== |
drafts/mppt_faq.txt · Last modified: 2021-09-30 07:18 by guystewart
