drafts:hub4-3-phase
| Both sides previous revisionPrevious revision | |||
| drafts:hub4-3-phase [2016-02-10 09:52] – mvader | drafts:hub4-3-phase [2016-02-24 11:43] (current) – removed mvader | ||
| Line 1: | Line 1: | ||
| - | ====== Hub-4 three phase ====== | ||
| - | Soon we expect to release CCGX v1.32, which includes the addition of three phase support for Hub-4. | ||
| - | To keep the text short, it refers to Multis. Also Quattros can be used. Both are bi-directional inverter/ | ||
| - | * The Multis need to be configured as a three-phase system. Use VE.Bus Quick Configure or VE.Bus System Configurator for this. | ||
| - | * Update all Multis to firmware 405 or newer | ||
| - | * Install the Hub4 Assistant in all units: all the phase-masters but also all slaves (if any) | ||
| - | * Three phase loads: it is possible to connect three-phase loads to the AC out of the Multis, also called the UPS-output in a Hub-4 system. Those loads will be powered from the battery during a power failure. | ||
| - | ===== Power regulation details - phase compensation setting ===== | ||
| - | In a three-phase Hub-4 system, there is at least one Multi installed on each phase. We recommend setting the system to regulate the total power of the three phases to zero. This is called phase-compensation, | ||
| - | With phase-compensation enabled, all the inverter/ | ||
| - | When the system as a whole produces power (PV power exceeds consumption), | ||
| - | When the system as a whole consumes power (Consumption exceeds PV production), | ||
| - | === Disabling phase compensation === | ||
| - | In a hub-4 system it is still possible to balance the grid power of each phase to 0W. Disable phase compensation. This would however cause significant losses, because power will flow from one phase to another through the DC connections. Causing losses when converting from AC to DC on one phase and then from DC to AC and the other phase. | ||
| - | Phase compensation, | ||
| - | ===== Maximum charge current limitation ===== | ||
| - | In a multi-phase system, the charge current is configured per phase. There is not a total charge current which the system adheres too. This means that, for example when there is a relatively small battery bank, and a huge over production of PV on L1, and not on the other phases, only part of that over production on L1 will be used to charge the battery. | ||
drafts/hub4-3-phase.1455094326.txt.gz · Last modified: by mvader
