drafts:error_codes
drafts:error_codes [2020-09-10 11:12] – [Err 43 - Inverter shutdown (Ground Fault)] rvanzundert | drafts:error_codes [2020-09-16 23:22] – [DISQUS] mvader | ||
Line 46: | Line 46: | ||
==== Err 14 - Battery low temperature ==== | ==== Err 14 - Battery low temperature ==== | ||
- | The charger is stopped | + | The charger is stopped |
This error will auto-reset after charger has cooled down. | This error will auto-reset after charger has cooled down. | ||
- | Check the ambient temperature and check for obstructions near the heatsink. | + | Check the ambient temperature and check for obstructions near heatsinks or fan inlets. |
Line 142: | Line 142: | ||
==== Err 43 - Inverter shutdown (Ground Fault) ==== | ==== Err 43 - Inverter shutdown (Ground Fault) ==== | ||
The voltage difference between Neutral and Ground is too high. | The voltage difference between Neutral and Ground is too high. | ||
- | Possible causes: | + | |
- | * The ground wire in the installation is not ok or not connected | + | Inverter |
- | * Line and Neutral are swapped in the installation (grid connected Multi using AC inputs). | + | * The internal ground relay is activated but the voltage over the relay is too high. The relay might be damaged. |
- | * The internal ground relay is activated but the voltage over the relay is too high. The relay might be damaged (stand-alone Inverter mode) | + | Multi (connected to the grid): |
This error will not auto-reset. Check the installation and restart the unit using the power-switch. | This error will not auto-reset. Check the installation and restart the unit using the power-switch. | ||
- | ==== Err 50 - Inverter overload ==== | + | ==== Err 50, Err 52 - Inverter overload, Inverter peak current |
Some loads like motors or pumps draw large inrush currents in a start-up situation. In such circumstances, | Some loads like motors or pumps draw large inrush currents in a start-up situation. In such circumstances, | ||
After three restarts followed by another overload within 30 seconds of restarting, the inverter will shutdown and remain off. To restart the inverter, switch it Off, then On. | After three restarts followed by another overload within 30 seconds of restarting, the inverter will shutdown and remain off. To restart the inverter, switch it Off, then On. | ||
Line 161: | Line 166: | ||
The inverter will restart after 30 seconds. The inverter will not stay off after multiple retries. | The inverter will restart after 30 seconds. The inverter will not stay off after multiple retries. | ||
- | ==== Err 52 - Inverter | + | ==== Err 53, Err 54 - Inverter |
- | If the error persists reduce the load on the AC out terminal by switching off or disconnecting appliances. | + | If the battery voltage is getting low and a large load is applied to the AC output the inverter is unable to maintain the proper output voltage. |
+ | Re-charge the battery | ||
- | This error will auto-restart after 30s, after 3 attempts | + | ==== Err 57 - Inverter ac voltage on output ==== |
+ | There is already AC voltage on the AC out terminal before switching on the inverter. Check that the AC out is not connected | ||
- | ==== Err 53 - Inverter dc level (internal dc rail voltage) ==== | + | This error will not auto-reset. Check the installation and restart the unit using the power-switch. |
- | A possible cause is that the battery needs to be charged. | + | |
- | This error will auto-reset when the internal dc voltage recovers. | + | ==== Err 55, Err 56, Err 58 - Inverter |
- | + | The inverter performs diagnostic tests before | |
- | ==== Err 54 - Inverter ac level (output voltage not ok) ==== | + | |
- | ==== Err 55 - Inverter dc fail (dc on output) ==== | + | |
- | ==== Err 56 - Inverter ac fail (shape wrong) ==== | + | |
- | ==== Err 57 - Inverter | + | |
- | There is already AC voltage on the AC out terminal | + | |
- | This error will not auto-reset. Check the installation and restart the unit using the power-switch. | + | |
- | ==== Err 58 - Inverter bridge fault ==== | + | First try to restart the inverter, by switching it Off, and then On. If error persists the inverter is probably faulty. |
Line 247: | Line 243: | ||
Please do report this to your Victron dealer and ask him to escalate it to Victron; as this error should never happen. Preferably include firmware version and any other specifics (VRM URL, VictronConnect screenshots or similar). | Please do report this to your Victron dealer and ask him to escalate it to Victron; as this error should never happen. Preferably include firmware version and any other specifics (VRM URL, VictronConnect screenshots or similar). | ||
+ | ==== Err 200 .. Err 255 - Internal error ==== | ||
+ | Internal diagnostics failure. | ||
+ | First try to restart the device, by switching it Off, and then On. If error persists the device is probably faulty. | ||
- | ~~DISQUS~~ | ||
