drafts:easysolar-ii-gx
drafts:easysolar-ii-gx [2019-04-04 15:45] – guy_stewart | drafts:easysolar-ii-gx [2019-04-10 13:19] – [SmartSolar MPPT solar charge controller] guy_stewart | ||
Line 25: | Line 25: | ||
- | The MPPT solar charge controller is programmable | + | The MPPT solar charge controller is programmable |
+ | The VE.Direct port that is located on the EasySolar-II GX is connected to the GX device, not the MPPT. It cannot be used for connection of USB to VE.Direct cable for programming the MPPT. | ||
+ | MPPT programming must be done via a [[https:// | ||
==== Multiplus Inverter / Charger ==== | ==== Multiplus Inverter / Charger ==== |
