drafts:dc_distribution
drafts:dc_distribution [2018-07-30 11:19] – [Fuses] guystewart | drafts:dc_distribution [2019-10-18 13:14] (current) – guy_stewart | ||
- | + | moved to https:// | |
- | ====== Lynx DC distribution system ====== | + | |
- | The lynx system is a modular DC bus bar system used to connect batteries, DC equipment and provide fusing and battery monitoring. | + | |
- | It consists of the following modules: | + | |
- | * Lynx Power In | + | |
- | * Lynx Shunt | + | |
- | * Lynx Distributor | + | |
- | Information on these 3 parts can be found below, but also in this [[https:// | + | |
- | ===== Lynx Power in ===== | + | |
- | The lynx power in module is used to connect batteries. It contains a negative and positive DC bus-bar with M8 bolts to connect batteries cables to. | + | |
- | ===== Lynx shunt ===== | + | |
- | The Lynx shunt contains a positive bus-bar with space to mount a fuse and a negative bus-bar with a shunt. | + | |
- | It also contains battery monitor electronics. The Lynx shunt can send via the VE.CAN bus battery motoring information to a CCGX or VGX or to a third party can bus monitoring system, such as a NMEA2000 (check with Johannes). The CCGX, VGX or third party display acts as battery monitor display and is also used to set up the built-in batter monitor. | + | |
- | The Lynx shunt is available in two models: | + | |
- | * VE.CAN | + | |
- | * VE.NET (depreciated) | + | |
- | ==== Fuse ==== | + | |
- | CIP140325000 - Fuse CNN 325A/80V for Lynx shunt | + | |
- | Or alternatively a [[http:// | + | |
- | ==== Shunt ==== | + | |
- | Rated at 1000 A | + | |
- | ==== Setup ==== | + | |
- | Setup is like setting up a BMV and this is done via the CCGX or VGX. | + | |
- | To find out the meaning of the various settings, please see the [[https:// | + | |
- | Please don’t use the 2-pin terminal block on the Lynx-shunt. | + | |
- | FAQ | + | |
- | Q Is there a way of setting the battery instance? | + | |
- | A There is a program available to change this but as the default is 0, which is the same as what a CCGX reads we would not advise changing this!! | + | |
- | ===== Lynx Distributor ===== | + | |
- | Contains positive and negative bus-bar and provides a connection for for 4 individual DC equipment or load or DC groups. It has a space for a individual DC fuses per DC group and a led for each fuse to indicate if fuse is blown. | + | |
- | * Green led = fuse is okay | + | |
- | * Red led = blown fuse | + | |
- | ==== Fuses ==== | + | |
- | Uses MEGA fuses. Please note that some MEGA fuses are only rated to 36Volt (suitable for 24V systems), You must use 64V rated fuses for 48V systems. | + | |
- | ==== Installation ==== | + | |
- | Connectors and dip-switches: | + | |
- | * The R11 connector is to power the Lynx-distributor from the Lynx-shunt | + | |
- | * The DIP switch on the Lynx-distributor are for specific manual settings, to do with our 24V batteries. Please don’t touch. | + | |
- | * The 6-pin header block on the Lynx Distributor is for reading out the fuses, but this feature is not supported. | + | |
- | FAQ | + | |
- | Q There is a small 4-pin cable shipped with the Distributor - I can only assume that the cable interconnects between the Shunt and Distributor? | + | |
- | A Yes, but this has only to power the LED’s on the distributor, | + | |
- | Q The Distributer has a DIP switch. What are the settings? | + | |
- | A That’s for manual settings, please don’t touch as the system will auto configure (up to 32 battery’s ) | + | |
- | Q The Distributer has a 6-pin header block. What is it for? | + | |
- | A read out of fuses, not supported yet. | + | |
- | ==== Customer Images ==== | + | |
- | Here are some images from customer' | + | |
- | **[[https:// | + | |
- | https:// | + | |
- | **[[http:// | + | |
- | [[https:// | + | |
drafts/dc_distribution.1532942346.txt.gz · Last modified: 2018-07-30 11:19 by guystewart
