drafts:dc_distribution
drafts:dc_distribution [2018-10-11 12:57] – [Why Fuse the Bus?] guystewart | drafts:dc_distribution [2019-10-17 14:11] – [Lynx shunt] guy_stewart | ||
Line 7: | Line 7: | ||
It consists of the following modules: | It consists of the following modules: | ||
- | * Lynx Power In | + | * [[https:// |
- | * Lynx Shunt | + | * [[https:// |
- | * Lynx Distributor | + | * [[https:// |
+ | You can use the Lynx Distributor or Lynx Power In without the Lynx Shunt. | ||
Information on these 3 parts can be found below, but also in this [[https:// | Information on these 3 parts can be found below, but also in this [[https:// | ||
Line 20: | Line 22: | ||
- | The lynx power in module is used to connect batteries. It contains a negative and positive DC bus-bar with M8 bolts to connect batteries cables | + | The lynx power in module is used to connect batteries. It contains a negative and positive DC bus-bar with M8 bolts in which to connect batteries cables. |
Line 29: | Line 31: | ||
The Lynx shunt contains a positive bus-bar with space to mount a fuse and a negative bus-bar with a shunt. | The Lynx shunt contains a positive bus-bar with space to mount a fuse and a negative bus-bar with a shunt. | ||
- | It also contains battery | + | It also contains battery |
- | The Lynx shunt is available in two models: | + | |
- | * VE.CAN | + | |
- | * VE.NET (depreciated) | + | |
+ | The Lynx shunt is available with a VE.Can connection. A previous model had a VE.Net connection and is now discontinued. | ||
==== Fuse ==== | ==== Fuse ==== | ||
Line 93: | Line 92: | ||
==== Fuses ==== | ==== Fuses ==== | ||
- | Uses MEGA fuses. Please note that some MEGA fuses are only rated to 36Volt (suitable for 24V systems), You must use 64V rated fuses for 48V systems. | + | Uses MEGA fuses. Please note that some MEGA fuses are only rated to 36Volt (suitable for 24V systems), You must use 58/64V rated fuses for 48V systems. |
==== Installation ==== | ==== Installation ==== | ||
Line 132: | Line 131: | ||
[[https:// | [[https:// | ||
drafts/dc_distribution.txt · Last modified: 2019-10-18 13:14 by guy_stewart
