drafts:acin_ignore_timer_using_ccgx_gen_start_stop_example
Last revisionBoth sides next revision
drafts:acin_ignore_timer_using_ccgx_gen_start_stop_example [2015-12-23 14:20] martijncosterdrafts:acin_ignore_timer_using_ccgx_gen_start_stop_example [2019-01-21 11:07] – [DISQUS] ictbeheer
-====== ACin ignore timer using CCGX Generator auto start/stop example ======+====== Example: ACin ignore timer using the CCGX Generator auto start/stop function ======
 Note that below functionality requires Color Control GX version v1.30 or newer. See [[ccgx:firmware_updating|here]] for update instructions.  Note that below functionality requires Color Control GX version v1.30 or newer. See [[ccgx:firmware_updating|here]] for update instructions.
Line 18: Line 18:
 {{:drafts:periodic_test_run.png?nolink&400|}} {{:drafts:periodic_test_run.png?nolink&400|}}
-  * **Test run interval**: Interval for the test run. For this examaple it is set to 1 day+  * **Test run interval**: Interval for the test run. For this example it is set to 1 day
   * **Skip test run if has been running for**: For this example will be set to: Start always   * **Skip test run if has been running for**: For this example will be set to: Start always
   * **Test interval start date**: The interval count will start based on this date, this setting can be set in the future and the interval will be ignored till the set date is reached.   * **Test interval start date**: The interval count will start based on this date, this setting can be set in the future and the interval will be ignored till the set date is reached.
Line 29: Line 29:
 Move the General Flag user assistant to the end of the list Move the General Flag user assistant to the end of the list
- **General flag user **+ **General flag user **\\
  Set to: Use general flag to ignore AC input 1   Set to: Use general flag to ignore AC input 1
- **Programmable relay** + **Programmable relay** \\
-You need to 2 instances of the 'Programmable relay' assistants. 1 to set the flag and 1 to clear the flag. +You need to 2 instances of the 'Programmable relay' assistants. 1 to set the flag and 1 to clear the flag. \\
- ** Set Flag when relais is open **+ ** Set Flag when relay is open **
   * Relay: Use General Flag   * Relay: Use General Flag
   * Action: Set relay on   * Action: Set relay on
Line 49: Line 49:
 ==== Wire the ColorControl relay to the Aux of Temp input on the Multi ==== ==== Wire the ColorControl relay to the Aux of Temp input on the Multi ====
-Last step is to wire the ColorControl relay to an AUX of Temp input that is defined in the assistant setup. The relay will short the input. The assistant will not ignore ACin when the relais is closed.  +Last step is to wire the ColorControl relay to an AUX or Temp input that is defined in the assistant setup. The relay will short the input and the assistant will not ignore ACin when the relais is closed.
-===== DISQUS =====
-~~DISQUS~~
drafts/acin_ignore_timer_using_ccgx_gen_start_stop_example.txt · Last modified: by 127.0.0.1
