drafts:acin_ignore_timer_using_ccgx_gen_start_stop_example
drafts:acin_ignore_timer_using_ccgx_gen_start_stop_example [2015-12-23 11:32] – martijncoster | drafts:acin_ignore_timer_using_ccgx_gen_start_stop_example [2019-01-21 11:07] – [DISQUS] ictbeheer | ||
- | ====== ACin ignore timer using CCGX Generator auto start/ | + | ====== |
Note that below functionality requires Color Control GX version v1.30 or newer. See [[ccgx: | Note that below functionality requires Color Control GX version v1.30 or newer. See [[ccgx: | ||
The CCGX internal relay can be used to start a generator. The relay can also be used to set other things. | The CCGX internal relay can be used to start a generator. The relay can also be used to set other things. | ||
- | For example in combination with an assistant and the use of an AUX input it can be used as a timer to ignore ACin on set times to make use of 'off peak tarrifs' | + | For example in combination with an assistant and the use of an AUX input it can be used as a timer to ignore ACin on set times to make use of 'off peak tarrifs' |
+ | 1. Setup the Generator start/stop function on the ColorControl | ||
+ | 2. Add and configure the assistants: ' | ||
+ | 3. Wire the ColorControl relay to the Aux of Temp input on the Multi | ||
===== Enable the start/stop function ===== | ===== Enable the start/stop function ===== | ||
Line 11: | Line 13: | ||
https:// | https:// | ||
- | * **Generator state**: Condition that is currently keeping | + | ==== Set the Test run condition ==== |
+ | The ' | ||
+ | We will use the test run condition to set the time when the relay will be closed. No other conditions will be used in this example. | ||
- | ===== Settings ===== | + | * **Test run interval**: Interval for the test run. For this example it is set to 1 day |
- | * **Conditions**: See [[# | + | * **Skip test run if has been running for**: For this example will be set to: Start always |
- | * Periodic | + | * **Test interval start date**: The interval count will start based on this date, this setting can be set in the future and the interval will be ignored till the set date is reached. |
+ | * **Start time**: Time when the relay will close. For this example 01:05 | ||
+ | * **Test duration**: Duration of the test. For this example set o 5:50 so the end time is 6:55 | ||
- | ==== Test run condition ==== | ||
- | Allows you to program a periodical test run.\\ | ||
- | {{:ccgx: | + | ===== Assistant Settings ===== |
- | * **Test run interval**: Test run will be performed periodically based on this setting | + | To make it work add and configure the assistants: ' |
- | * **Skip test run if has been running for**: The test will be skipped if during | + | Move the General Flag user assistant to the end of the list |
- | * **Test interval start date**: The interval count will start based on this date, this setting can be set in the future | + | |
- | * **Start time**: Time of day in which the generator will start | + | **General flag user **\\ |
- | * **Test duration**: Duration of the test | + | Set to: Use general flag to ignore AC input 1 |
+ | **Programmable relay** \\ | ||
+ | You need to 2 instances of the ' | ||
+ | * Action: Set relay on | ||
+ | * Switch conditions : Set checkbox: Input signal (Auxilary 1, Auxilary 2 or Temp sense input) | ||
+ | * Extra drive options: leave open | ||
+ | * Drive based on input signal: Choose correct input. | ||
+ | * Action: Set relay off | ||
- | ===== DISQUS ===== | + | ==== Wire the ColorControl relay to the Aux of Temp input on the Multi ==== |
- | ~~DISQUS~~ | + | Last step is to wire the ColorControl relay to an AUX or Temp input that is defined in the assistant setup. The relay will short the input and the assistant will not ignore ACin when the relais is closed. |
drafts/acin_ignore_timer_using_ccgx_gen_start_stop_example.txt · Last modified: 2019-01-22 10:16 by 127.0.0.1
