drafts:acin_ignore_timer_using_ccgx_gen_start_stop_example
drafts:acin_ignore_timer_using_ccgx_gen_start_stop_example [2015-12-23 11:21] – created martijncoster | drafts:acin_ignore_timer_using_ccgx_gen_start_stop_example [2015-12-23 16:10] – martijncoster | ||
- | ====== ACin ignore timer using CCGX Generator auto start/ | + | ====== |
Note that below functionality requires Color Control GX version v1.30 or newer. See [[ccgx: | Note that below functionality requires Color Control GX version v1.30 or newer. See [[ccgx: | ||
The CCGX internal relay can be used to start a generator. The relay can also be used to set other things. | The CCGX internal relay can be used to start a generator. The relay can also be used to set other things. | ||
- | For example in combination with an assistant and the use of an AUX input it can be used as a timer to ignore ACin on set times to make use of 'off peak tarrifs' | + | For example in combination with an assistant and the use of an AUX input it can be used as a timer to ignore ACin on set times to make use of 'off peak tarrifs' |
+ | 1. Setup the Generator start/stop function on the ColorControl | ||
+ | 2. Add and configure the assistants: ' | ||
+ | 3. Wire the ColorControl relay to the Aux of Temp input on the Multi | ||
===== Enable the start/stop function ===== | ===== Enable the start/stop function ===== | ||
Line 13: | Line 13: | ||
https:// | https:// | ||
- | * **Generator state**: Condition that is currently keeping | + | ==== Set the Test run condition ==== |
+ | The ' | ||
+ | We will use the test run condition to set the time when the relay will be closed. No other conditions will be used in this example. | ||
- | ===== Settings ===== | + | * **Test run interval**: Interval for the test run. For this example it is set to 1 day |
+ | * **Skip test run if has been running for**: For this example will be set to: Start always | ||
+ | * **Test interval start date**: The interval count will start based on this date, this setting can be set in the future and the interval will be ignored till the set date is reached. | ||
+ | * **Start time**: Time when the relay will close. For this example 01:05 | ||
+ | * **Test duration**: Duration of the test. For this example set o 5:50 so the end time is 6:55 | ||
- | * **Conditions**: | ||
- | ===== Conditions | + | ===== Assistant Settings |
- | * Periodic test run | + | To make it work add and configure the assistants: ' |
- | ==== Condition settings ==== | + | Move the General Flag user assistant to the end of the list |
+ | Set to: Use general flag to ignore AC input 1 | ||
+ | You need to 2 instances of the ' | ||
+ | ** Set Flag when relay is open ** | ||
+ | * Relay: Use General Flag | ||
+ | * Action: Set relay on | ||
+ | * Switch conditions : Set checkbox: Input signal (Auxilary 1, Auxilary 2 or Temp sense input) | ||
+ | * Extra drive options: leave open | ||
+ | * Drive based on input signal: Choose correct input. set to open and 5 second | ||
- | ==== Test run condition ==== | + | |
- | Allows you to program a periodical test run.\\ | + | |
- | + | * Action: Set relay off | |
- | {{: | + | * Switch conditions : Set checkbox: Input signal (Auxilary 1, Auxilary 2 or Temp sense input) |
- | * **Test run interval**: Test run will be performed periodically based on this setting | + | * Drive based on input signal: Choose correct input. |
- | * **Skip test run if has been running for**: The test will be skipped if during the test run interval the generator was running at least the number of hours set on this setting. | + | |
- | * **Test interval start date**: The interval count will start based on this date, this setting can be set in the future | + | |
- | * **Start time**: Time of day in which the generator | + | ==== Wire the ColorControl relay to the Aux of Temp input on the Multi ==== |
+ | Last step is to wire the ColorControl relay to an AUX or Temp input that is defined | ||
+ | ~~DISQUS~~ | ||
- | * **Test duration**: Duration of the test |
drafts/acin_ignore_timer_using_ccgx_gen_start_stop_example.txt · Last modified: 2019-01-22 10:16 by 127.0.0.1
