dc_distribution
dc_distribution [2021-03-28 20:55] – mvader | dc_distribution [2021-04-12 19:40] – [Installation] mvader | ||
Line 78: | Line 78: | ||
Connectors and dip-switches: | Connectors and dip-switches: | ||
- | * The R11 connector is to power the Lynx-distributor from the Lynx-shunt | + | * The R10 connector is to power the Lynx-distributor from the Lynx-shunt |
* The DIP switch on the Lynx-distributor are for specific manual settings, to do with our 24V batteries. Please don’t touch. | * The DIP switch on the Lynx-distributor are for specific manual settings, to do with our 24V batteries. Please don’t touch. | ||
* The 6-pin header block on the Lynx Distributor is for reading out the fuses, but this feature is not supported. | * The 6-pin header block on the Lynx Distributor is for reading out the fuses, but this feature is not supported. |
dc_distribution.txt · Last modified: 2021-04-19 08:55 by marmour
