dc_distribution
dc_distribution [2020-01-02 16:03] – [Installation] marmour | dc_distribution [2020-09-07 23:57] – tpwchr | ||
Line 22: | Line 22: | ||
The Power In contains a negative and positive DC bus-bar with M8 bolts in which to connect batteries cables. It can take cables up to 22 mm in diameter through the bottom entry guides, and no limit via the two side connections. | The Power In contains a negative and positive DC bus-bar with M8 bolts in which to connect batteries cables. It can take cables up to 22 mm in diameter through the bottom entry guides, and no limit via the two side connections. | ||
===== Lynx shunt ===== | ===== Lynx shunt ===== | ||
Line 54: | Line 55: | ||
A - There is a program available to change this but as the default is 0, which is the same as what a CCGX reads we would not advise changing this!! | A - There is a program available to change this but as the default is 0, which is the same as what a CCGX reads we would not advise changing this!! | ||
+ | Further[[https:// | ||
===== Lynx Distributor ===== | ===== Lynx Distributor ===== |
dc_distribution.txt · Last modified: 2021-04-19 08:55 by marmour
