dc_distribution
dc_distribution [2019-10-19 12:42] – [Lynx Power in] guy_stewart | dc_distribution [2020-01-02 16:03] – [Installation] marmour | ||
Line 19: | Line 19: | ||
- | The lynx power in module is used to connect batteries via an external fuse. It can be useful if you have multiple parallel strings. Due the extremely high short circuit current potential of most battery banks, it is suggested to use an external fuse system with an appropriate fault current interruption rating (such as an NH HRC). | + | The lynx power in module is used to connect batteries via an external fuse. It can be useful if you have multiple parallel strings. Due to the extremely high short circuit current potential of most battery banks, it is suggested to use an external fuse system with an appropriate fault current interruption rating (such as an NH HRC). |
- | The Power In contains a negative and positive DC bus-bar with M8 bolts in which to connect batteries cables. It can take cables up to 22 mm in diameter | + | The Power In contains a negative and positive DC bus-bar with M8 bolts in which to connect batteries cables. It can take cables up to 22 mm in diameter |
===== Lynx shunt ===== | ===== Lynx shunt ===== | ||
Line 67: | Line 67: | ||
RJ11 fly leads are used to connect the Lynx Shunt to the Distributor. This RJ11 cable is supplied with the Distributor in the box. There are two ports on the Lynx Shunt, and it is possible to use either. | RJ11 fly leads are used to connect the Lynx Shunt to the Distributor. This RJ11 cable is supplied with the Distributor in the box. There are two ports on the Lynx Shunt, and it is possible to use either. | ||
- | When all is OK, only the central | + | When all is OK, only the central |
A future upgrade is planned to also send info back to the GX device over the VE-can, but is not yet implemented. | A future upgrade is planned to also send info back to the GX device over the VE-can, but is not yet implemented. | ||
Line 85: | Line 85: | ||
Q - There is a small 4-pin cable shipped with the Distributor - I can only assume that the cable interconnects between the Shunt and Distributor? | Q - There is a small 4-pin cable shipped with the Distributor - I can only assume that the cable interconnects between the Shunt and Distributor? | ||
- | A - Yes, but this has only to power the LED’s | + | A - Yes, but this has only to power the LEDs on the distributor, |
- | Q - The Distributer | + | Q - The Distributor |
A - That’s for manual settings, please don’t touch as the system will auto configure (up to 32 battery’s ) | A - That’s for manual settings, please don’t touch as the system will auto configure (up to 32 battery’s ) | ||
A - In the future, the read out of fuses, but this is not supported yet. | A - In the future, the read out of fuses, but this is not supported yet. |
dc_distribution.txt · Last modified: 2021-04-19 08:55 by marmour
