dc_distribution
dc_distribution [2019-10-19 06:39] – guy_stewart | dc_distribution [2020-01-12 12:42] – guy_stewart | ||
Line 19: | Line 19: | ||
- | The lynx power in module is used to connect batteries. It contains a negative and positive DC bus-bar with M8 bolts in which to connect batteries cables. | + | The lynx power in module is used to connect batteries |
+ | The Power In contains a negative and positive DC bus-bar with M8 bolts in which to connect batteries cables. It can take cables up to 22 mm in diameter through the bottom entry guides, and no limit via the two side connections. | ||
===== Lynx shunt ===== | ===== Lynx shunt ===== | ||
Line 53: | Line 55: | ||
A - There is a program available to change this but as the default is 0, which is the same as what a CCGX reads we would not advise changing this!! | A - There is a program available to change this but as the default is 0, which is the same as what a CCGX reads we would not advise changing this!! | ||
+ | Further[[https:// | ||
===== Lynx Distributor ===== | ===== Lynx Distributor ===== | ||
Line 66: | Line 69: | ||
RJ11 fly leads are used to connect the Lynx Shunt to the Distributor. This RJ11 cable is supplied with the Distributor in the box. There are two ports on the Lynx Shunt, and it is possible to use either. | RJ11 fly leads are used to connect the Lynx Shunt to the Distributor. This RJ11 cable is supplied with the Distributor in the box. There are two ports on the Lynx Shunt, and it is possible to use either. | ||
- | When all is OK, only the central | + | When all is OK, only the central |
A future upgrade is planned to also send info back to the GX device over the VE-can, but is not yet implemented. | A future upgrade is planned to also send info back to the GX device over the VE-can, but is not yet implemented. | ||
Line 84: | Line 87: | ||
Q - There is a small 4-pin cable shipped with the Distributor - I can only assume that the cable interconnects between the Shunt and Distributor? | Q - There is a small 4-pin cable shipped with the Distributor - I can only assume that the cable interconnects between the Shunt and Distributor? | ||
- | A - Yes, but this has only to power the LED’s | + | A - Yes, but this has only to power the LEDs on the distributor, |
- | Q - The Distributer | + | Q - The Distributor |
A - That’s for manual settings, please don’t touch as the system will auto configure (up to 32 battery’s ) | A - That’s for manual settings, please don’t touch as the system will auto configure (up to 32 battery’s ) | ||
A - In the future, the read out of fuses, but this is not supported yet. | A - In the future, the read out of fuses, but this is not supported yet. |
dc_distribution.txt · Last modified: 2021-04-19 08:55 by marmour
