dc_distribution
dc_distribution [2019-10-19 06:39] – guy_stewart | dc_distribution [2019-10-19 12:42] – [Lynx Power in] guy_stewart | ||
Line 19: | Line 19: | ||
- | The lynx power in module is used to connect batteries. It contains a negative and positive DC bus-bar with M8 bolts in which to connect batteries cables. | + | The lynx power in module is used to connect batteries |
+ | The Power In contains a negative and positive DC bus-bar with M8 bolts in which to connect batteries cables. It can take cables up to 22 mm in diameter though the bottom entry guides, and no limit via the two side connections. | ||
===== Lynx shunt ===== | ===== Lynx shunt ===== | ||
dc_distribution.txt · Last modified: 2021-04-19 08:55 by marmour
