dc_coupling:using_bmv_soc_in_a_vebus_assistant_setup
drafts:using_bmv_soc_in_a_vebus_assistant_setup [2015-04-07 12:20] – john_r | dc_coupling:using_bmv_soc_in_a_vebus_assistant_setup [2019-01-22 10:16] (current) – external edit 127.0.0.1 | ||
- | ====== BMV state of charge | + | ====== |
- | This can be very useful for DC connected solar energy systems where the VE.Bus SOC is not accurate. The goal is to ignore AC in, unless the battery SOC measured via the BMV falls below 50%. For this to happen we need two wires between the BMV relay and Aux1 on the Multi. Configure the BMV to close its relay when the SOC falls below 50%. [[http:// | + | This can be very useful for DC connected solar energy systems where the VE.Bus SOC is not accurate. The goal is to ignore AC in (force Inverter mode), unless the battery SOC measured via the BMV falls below 50%. Configure the BMV to close its relay when the SOC falls below 50%. [[https:// |
Now the BMV will close the relay when the battery SOC is below 50% and this signal can be connected to Aux1 or the temperature input, for example, on the Multi. | Now the BMV will close the relay when the battery SOC is below 50% and this signal can be connected to Aux1 or the temperature input, for example, on the Multi. | ||
- | ==== Load assistants | + | ===== Wiring ===== |
+ | For this to happen we need two wires between the BMV relay and Aux1 on the Multi: | ||
+ | ==== Load and configure the Assistants | ||
The next step is to load 3 assistants in the Multi. | The next step is to load 3 assistants in the Multi. | ||
- | 1st assistant " | + | 1st assistant " |
* Use General flag | * Use General flag | ||
- | * Set Relay off | + | * Set Relay on |
- | * When auxiliary input 1 is open for 0 seconds | + | * When auxiliary input 1 is open for 1 seconds |
- | 2nd assistant " | + | 2nd assistant " |
- | * Set Relay on | + | * Set Relay off |
* When auxiliary input 1 is closed for 0 seconds | * When auxiliary input 1 is closed for 0 seconds | ||
Line 24: | Line 29: | ||
* Use general flag to ignore AC input 1 | * Use general flag to ignore AC input 1 | ||
- | With these three assistants used together AC input 1 will be ignored when the BMV closes its relay. | + | With these three assistants used together AC input 1 will be used (not ignored) when the BMV closes its relay. |
+ | ===== Related info ===== | ||
+ | ==== 1. Using ESS instead of above ==== | ||
+ | For many applications, | ||
+ | [[ess: | ||
+ | ==== 2. Adding the PV Inverter Assistant ==== | ||
+ | For those people who do not want to use the ESS Assistant, but want to add AC-Coupled PV on the output of the Multi, they can use the above three assistants, plus at the bottom position add the "PV Inverter support" | ||
- | For those people who do not want to use Hub 2 assistants (AC out connected solar energy) they can use the above three assistants, plus at bottom position assistant " | ||
dc_coupling/using_bmv_soc_in_a_vebus_assistant_setup.1428402009.txt.gz · Last modified: 2015-04-07 12:20 by john_r
