dc_coupling:using_bmv_soc_in_a_vebus_assistant_setup
dc_coupling:using_bmv_soc_in_a_vebus_assistant_setup [2015-09-04 16:22] – Make description match detail and image ptomli | dc_coupling:using_bmv_soc_in_a_vebus_assistant_setup [2019-01-21 11:01] – [2. Adding the PV Inverter Assistant] ictbeheer | ||
- | This can be very useful for DC connected solar energy systems where the VE.Bus SOC is not accurate. The goal is to ignore AC in, unless the battery SOC measured via the BMV falls below 50%. Configure the BMV to close its relay when the SOC falls below 50%. [[http:// | + | This can be very useful for DC connected solar energy systems where the VE.Bus SOC is not accurate. The goal is to ignore AC in (force Inverter mode), unless the battery SOC measured via the BMV falls below 50%. Configure the BMV to close its relay when the SOC falls below 50%. [[https:// |
Now the BMV will close the relay when the battery SOC is below 50% and this signal can be connected to Aux1 or the temperature input, for example, on the Multi. | Now the BMV will close the relay when the battery SOC is below 50% and this signal can be connected to Aux1 or the temperature input, for example, on the Multi. | ||
Line 33: | Line 33: | ||
- | ===== Use with HUB2 system without Hub2 assistant | + | ===== Related info ===== |
+ | ==== 1. Using ESS instead of above ==== | ||
+ | For many applications, | ||
+ | [[ess: | ||
+ | ==== 2. Adding the PV Inverter Assistant ==== | ||
+ | For those people who do not want to use the ESS Assistant, but want to add AC-Coupled PV on the output of the Multi, they can use the above three assistants, plus at the bottom position add the "PV Inverter support" | ||
- | For those people who do not want to use Hub 2 assistants (AC out connected solar energy) they can use the above three assistants, plus at the bottom position assistant " | ||
- | ~~DISQUS~~ | ||
dc_coupling/using_bmv_soc_in_a_vebus_assistant_setup.txt · Last modified: 2019-01-22 10:16 by 127.0.0.1
