dc_coupling:prioritize_solar
| dc_coupling:prioritize_solar [2014-08-03 22:08] – [Question] mvader | dc_coupling:prioritize_solar [2019-01-22 09:16] (current) – external edit 127.0.0.1 | ||
| Line 1: | Line 1: | ||
| - | ====== How to prioritize solar in a dc-coupled system ====== | + | ====== How to prioritize solar in a DC-coupled system ====== |
| ===== System ===== | ===== System ===== | ||
| - | Multi, powered by the grid, solar charger, batteries, | + | Multi, powered by the grid, solar charger, batteries, |
| ===== Question ===== | ===== Question ===== | ||
| - | Out of the box, a Multi or Quattro inverter/ | + | Out of the box, a Multi or Quattro inverter/ |
| - | Since there is solar power, I want to first use solar power, and only when there is no or not enough solar fall back to the grid. | + | Since there is solar power, I want to first use solar power, and only when there is none or not enough solar power I want it to fall back to the grid. |
| How can I do that? | How can I do that? | ||
| Line 19: | Line 19: | ||
| Use the [[assistants: | Use the [[assistants: | ||
| - | To install this assistant, see instructions here: [[assistants: | + | To install this assistant, see the instructions here: [[assistants: |
| This assistant has more relevant optional features: | This assistant has more relevant optional features: | ||
| Line 29: | Line 29: | ||
| ===== Answer (old micro) ===== | ===== Answer (old micro) ===== | ||
| - | Use the virtual switch to enable ignore the ac input, based on battery voltage, and optionally also on power being drawn by the ac loads. | + | Use the virtual switch to enable ignore the AC input, based on battery voltage, and optionally also on power being drawn by the AC loads. |
| We will add more information and some screenshots explaining this installation soon. | We will add more information and some screenshots explaining this installation soon. | ||
| + | ===== DISQUS ===== | ||
| ~~DISQUS~~ | ~~DISQUS~~ | ||
dc_coupling/prioritize_solar.1407103733.txt.gz · Last modified: by mvader
