dc_coupling:prioritize_solar
dc_coupling:prioritize_solar [2014-08-04 00:08] – [Question] mvader | dc_coupling:prioritize_solar [2019-01-22 10:16] (current) – external edit 127.0.0.1 | ||
- | ====== How to prioritize solar in a dc-coupled system ====== | + | ====== How to prioritize solar in a DC-coupled system ====== |
===== System ===== | ===== System ===== | ||
- | Multi, powered by the grid, solar charger, batteries, | + | Multi, powered by the grid, solar charger, batteries, |
===== Question ===== | ===== Question ===== | ||
- | Out of the box, a Multi or Quattro inverter/ | + | Out of the box, a Multi or Quattro inverter/ |
- | Since there is solar power, I want to first use solar power, and only when there is no or not enough solar fall back to the grid. | + | Since there is solar power, I want to first use solar power, and only when there is none or not enough solar power I want it to fall back to the grid. |
How can I do that? | How can I do that? | ||
Line 19: | Line 19: | ||
Use the [[assistants: | Use the [[assistants: | ||
- | To install this assistant, see instructions here: [[assistants: | + | To install this assistant, see the instructions here: [[assistants: |
This assistant has more relevant optional features: | This assistant has more relevant optional features: | ||
Line 29: | Line 29: | ||
===== Answer (old micro) ===== | ===== Answer (old micro) ===== | ||
- | Use the virtual switch to enable ignore the ac input, based on battery voltage, and optionally also on power being drawn by the ac loads. | + | Use the virtual switch to enable ignore the AC input, based on battery voltage, and optionally also on power being drawn by the AC loads. |
We will add more information and some screenshots explaining this installation soon. | We will add more information and some screenshots explaining this installation soon. | ||
dc_coupling/prioritize_solar.txt · Last modified: 2019-01-22 10:16 by 127.0.0.1
